zs1vdv
July 12, 2017, 8:09pm
#1
I have setup my raspberry pi by following http://satnogs.readthedocs.io/en/stable/satnogs-client/doc/raspi-install.html .
Configured on dev network VanHome #114 .
It looks like the software is checking in, but not showing online.
What could be wrong?
Resolved by marking it online through our admin interface.
zs1vdv
July 13, 2017, 5:47am
#3
Thank you, this was me who was blind
What was the resolution to this? I have one in Dev Desert Rat #118 that isn’t showing online.
No errors show up when running Satnogs-client
zs1vdv
July 17, 2017, 5:46am
#5
From what I can see it looks like the client is not logging in.
Have you checked the your .env file for the correct details?
export SATNOGS_API_TOKEN="1234567890qwertyuiopasdfghjklzxcvbnm1234"
export SATNOGS_STATION_ID="65"
export SATNOGS_STATION_LAT="40.662"
export SATNOGS_STATION_LON="23.337"
export SATNOGS_STATION_ELEV="150"
export SATNOGS_NETWORK_API_URL="https://network-dev.satnogs.org/api/"
Just replace the API_TOKEN with yours from the network dev site. and the station information with your details.
Could it maybe be firewall on your side?
Well I ruled out firewall because from my Pi I can ping network-dev.satnogs.org ,
and I verified my .env file.
When I build the client side, I did Touch Satnogs.env
, and then Nano the export data above.
Did I miss something when I did Touch Satnogs.env
? I even sourced it as well.
zs1vdv
July 17, 2017, 6:39am
#7
The filename for me is ~/.env not ~/Satnogs.env
So theoretically (because I didn’t, couldn’t see a ~/.env
I should be able to Touch ~/.env
and edit accordingly…right?
let me try that, I’ll let you all know
how it goes
Doesn’t look like it came up.
I did mv Satnogs.env ~/.env
and rebooted, and it’s still showing up offline . I re-did the source ~/.env
to be safe prior to rebooting.
Well that was weird, post reboot the ~/.env file didn’t exist. I just rebuild it and didn’t need to reboot anything.
Still offline
zs1vdv
July 19, 2017, 6:00am
#13
I suggest going on the irc channel and come chat to some people about your problem.
https://satnogs.org/contact/
