New 6-digit NORAD IDs from space-track
When does Gpredict plan to adopt (accommodate) using the new 6-digit NORAD IDs, e.g., 100100, which is listed in the TLE as:
1 A0100U 26156CC 26211.27629035 .00005551 00000-0 54953-3 0 9992
2 A0100 97.7499 111.3618 0010139 78.6726 281.5632 14.92209416 3423
Have a look at the GPredict github issue page Add Alpha-5 catalog number support by N6RFM · Pull Request #412 · csete/gpredict · GitHub
Thanks for the reply. I did, but when I tried to use to the TLE (in my previous post) in Gpredict, it created an object w/ a “0” NORAD ID that I couldn’t use/track in Gpredict, so I did the following trick w/ the TLE:
1 00100U 26156CC 26211.27629035 .00005551 00000-0 54953-3 0 9992
2 00100 97.7499 111.3618 0010139 78.6726 281.5632 14.92209416 3423
instead of the space-track original TLE:
