I have 2 separate ground stations running and one of them (station 3297) begins failing after successfully making 1 or 2 observations with the following error:
Prs3k@adsb-pi:~ $ systemctl status satnogs-client.service
● satnogs-client.service - SatNOGS client
Active: active (running) since Tue 2024-01-23 11:22:25 MST; 49min ago
Main PID: 420 (satnogs-client)
Tasks: 4 (limit: 4915)
CPU: 7.558s
└─420 /var/lib/satnogs/bin/python /var/lib/satnogs/bin/satnogs-client
Jan 23 11:22:35 adsb-pi satnogs-client[420]: return request(“get”, url, params=params, **kwargs)
Jan 23 11:22:35 adsb-pi satnogs-client[420]: File “/var/lib/satnogs/lib/python3.9/site-packages/requests/api.py”, line 59, in request
Jan 23 11:22:35 adsb-pi satnogs-client[420]: return session.request(method=method, url=url, **kwargs)
Jan 23 11:22:35 adsb-pi satnogs-client[420]: File “/var/lib/satnogs/lib/python3.9/site-packages/requests/sessions.py”, line 587, in request
Jan 23 11:22:35 adsb-pi satnogs-client[420]: resp = self.send(prep, **send_kwargs)
Jan 23 11:22:35 adsb-pi satnogs-client[420]: File “/var/lib/satnogs/lib/python3.9/site-packages/requests/sessions.py”, line 701, in send
Jan 23 11:22:35 adsb-pi satnogs-client[420]: r = adapter.send(request, **kwargs)
Jan 23 11:22:35 adsb-pi satnogs-client[420]: File “/var/lib/satnogs/lib/python3.9/site-packages/requests/adapters.py”, line 565, in send
Jan 23 11:22:35 adsb-pi satnogs-client[420]: raise ConnectionError(e, request=request)
Jan 23 11:22:35 adsb-pi satnogs-client[420]: requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘network.satnogs.org’, port=443): Max retries exceeded with url: /api/jobs/?ground_station=3297&lat=39.543&lon=-104.93&alt=1795 (Caused by NewConnectionError>
I tried reinstalling the image from scratch and get the same error. This did not start happening until the latest satnogs image updates were released. I’m able to ping the server just fine. I tried apt update, apt upgrade, apt dist-upgrade, satnogs-upgrade, and updating through satnogs-setup.
Dashboard: SatNOGS Network - Ground Station Team RKS (ADSB/UHF)
System configuration:
Installed: satnogs-client-ansible-202209101521, satnogs-client-1.8.1, satnogs-flowgraphs-1.4-1
Hardware: Raspberry Pi 4, RTL-SDR Blog V3, ADSB Antenna
