NAYIF-1 re-entry
In this thread we are going to track NAYIF-1 (EO-88, FUNCUBE-5) re-entry.
Here is one TLE based on 1682 - N5ZKK-VHF-Helical observations. Not very accurate but better than the current one.
NAYIF-1
1 42017U          23199.20000000  .00000000  00000-0  00000-0 0    03
2 42017  97.1939 272.0530 0014074 339.5038  39.3040 16.29558364    08
To station owners, as the TLE are expected to change a lot the next hours/days, please don’t schedule too far in the future, I would suggest 3-6h is good, except if you remove and re-schedule your observations when we have new TLE.
I’m planning on doing a demod on a bunch of observations that either has no frames or missing due to doppler. Sending them in via SiDS and tagging with the appropriate station name and location.
At the end of this we can do a DB export and sent it over to the EO-88 team. It would be cool if it could be added to the warehouse.
New TLE set:
NAYIF-1
1 42017U          23199.50000000  .00000000  00000-0  73850-3 0    02
2 42017  97.1939 272.6501 0014866 337.9521   4.8049 16.36239601    04
nayif_199_2.dat (6.3 KB)
sites.txt (2.6 KB)
One more TLE set:
NAYIF-1
1 42017U          23199.55000000  .00000000  00000-0  83527-5 0    01
2 42017  97.1939 273.1714 0014074 325.7704 310.4841 16.32569993    07
sites.txt (2.7 KB)
nayif_199_3.dat (8.6 KB)
One more TLE set using the latest observations of 657 - ZL2MST station:
NAYIF-1
1 42017U          23199.60000000  .00000000  00000-0  54118-3 0    09
2 42017  97.1939 273.0168 0015617 322.2433 251.5138 16.40624399    09
sites.txt (2.7 KB)
nayif_199_4.dat (9.5 KB)
Latest update:
NAYIF-1
1 42017U          23199.70000000  .00000000  00000-0  30378-3 0    02
2 42017  97.1939 273.0282 0015650 322.3877 123.0475 16.44176103    02
nayif_199_5.dat (11.4 KB)
sites.txt (2.7 KB)
Next TLE set:
NAYIF-1
1 42017U          23199.75000000  .00000000  00000-0  25592-3 0    09
2 42017  97.1939 272.8944 0015650 169.2329 212.6022 16.44009015    04
nayif_199_6.dat (12.9 KB)
sites.txt (2.7 KB)
Next update after pass over North America:
NAYIF-1
1 42017U          23199.80000000  .00000000  00000-0  14935-3 0    04
2 42017  97.1939 273.8306 0015468 168.9112 152.0659 16.51003060    05
Statement from twitter user G0MRF https://twitter.com/g0mrf/status/1681397433329172489
The last good observations confirm the tweet @SA2KNG posted. Our last reception of the satellite was from 908 - CA-USA Fixed VHF station at around 2023-07-18 18:31:45 UTC.
One station broke out in tears and produced these beautiful waterfalls.
</art>
RIP EO-88, Goodbye and thanks for all fun!
The results of the demodulation of the last days. I want to place them in DB as well but have not done so yet.
It has been demodulated with gr_satellites and bracketed --f_offset between 5kHz and 12kHz to catch the packages that was way off because of doppler change.
The kiss files contains data frames and timestamps, the csv is the same format as DB export.
The following is a combined and de-duplicated result for each observation, only in DB export format.
