I have added a new transmitter for EO-88 containing the current downlink frequency of the telemetry beacon. It is based on observations 1903, 1937, 1938, and 1954 (signal should be centered at 1.5 kHz).
It seems many of the Funcube-series satellites are drifting quite a lot; however, this one has been pretty stable over the last few days. Not sure when the “PE0SAT Move V TLM Beacon” was added, but it seems way off now.
Now I have the first observations (1973 and 1975) with the corrected frequency, and the audio signal is centered nicely around 1.5 kHz (where it is supposed to be)
I do not know about funcube dashboard or gr-satellites, but I have decoded over 1,000 packets from Nayif using your fcdec (https://github.com/csete/fcdec).
