My station is unable to upload anything. The observations are black with no waterfall and no audio. Restarting satnogs-client does not help.
Support info:
"versions": {
"satnogs-client": "1.4",
"satnogs-client-ansible": "202012231828",
"satnogs-flowgraphs": "1.3-1",
"gr-satnogs": "2.2.0.0-1",
"gr-soapy": "2.1.3-1",
"gnuradio": "3.8.2.0-2",
"satnogs-config": "0.11"
"state": {
"is-applied": true,
"pending-tags": null
"system": {
"date": "2021-01-27T12:26:09.425837+00:00",
"distribution": {
"DESCRIPTION": "Raspbian GNU/Linux 10 (buster)",
"RELEASE": "10",
"CODENAME": "buster",
"ID": "Raspbian"
"pending-updates": true,
"platform": {
"system": "Linux",
"node": "satnogs-fhab-1",
"release": "5.4.83-v7l+",
"version": "#1379 SMP Mon Dec 14 13:11:54 GMT 2020",
"machine": "armv7l",
"processor": ""
"memory": {
"total": 4013871104,
"available": 3679256576,
"percent": 8.3,
"used": 183197696,
"free": 3302608896,
"active": 411217920,
"inactive": 216293376,
"buffers": 99909632,
"cached": 428154880,
"shared": 8810496,
"slab": 54046720
"disk": {
"total": 30142779392,
"used": 5676032000,
"free": 23195947008,
"percent": 19.7
"configuration": {
"enable_iq_dump": true,
"hamlib_utils_rot_enabled": false,
"iq_dump_filename": "/tmp/.satnogs/iq.raw",
"satnogs_antenna": "RX",
"satnogs_post_observation_script": "/usr/local/bin/satnogs-post {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}",
"satnogs_rf_gain": 48.0,
"satnogs_rx_device": "rtlsdr",
"satnogs_station_elev": 67,
"satnogs_station_id": 1272,
"satnogs_station_lat": 56.82,
"satnogs_station_lon": 12.89
daemon.log:
Jan 26 11:39:24 satnogs-fhab-1 satnogs-client[374]: Found Rafael Micro R820T tuner
Jan 26 11:39:24 satnogs-fhab-1 satnogs-client[374]: [INFO] Opening Generic RTL2832U OEM :: 00000001...
Jan 26 11:39:25 satnogs-fhab-1 satnogs-client[374]: [R82XX] PLL not locked!
Jan 26 11:39:25 satnogs-fhab-1 satnogs-client[374]: [INFO] Using format CF32.
Jan 26 11:39:25 satnogs-fhab-1 satnogs-client[374]: Allocating 15 zero-copy buffers
Jan 26 11:46:38 satnogs-fhab-1 satnogs-client[374]: Found Rafael Micro R820T tuner
Jan 26 11:46:39 satnogs-fhab-1 satnogs-client[374]: [INFO] Opening Generic RTL2832U OEM :: 00000001...
Jan 26 11:46:39 satnogs-fhab-1 satnogs-client[374]: Found Rafael Micro R820T tuner
Jan 26 11:46:39 satnogs-fhab-1 satnogs-client[374]: [R82XX] PLL not locked!
Jan 26 11:46:39 satnogs-fhab-1 satnogs-client[374]: [INFO] Using format CF32.
Jan 26 11:46:39 satnogs-fhab-1 satnogs-client[374]: Allocating 15 zero-copy buffers
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: apscheduler.executors.default - ERROR - Job "get_jobs (trigger: interval[0:01:00], next run at: 2021-01-26 12:08:18 UTC)" raised an exception
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: Traceback (most recent call last):
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 426, in _make_request
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: six.raise_from(e, None)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "<string>", line 3, in raise_from
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 421, in _make_request
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: httplib_response = conn.getresponse()
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/usr/lib/python3.7/http/client.py", line 1336, in getresponse
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: response.begin()
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/usr/lib/python3.7/http/client.py", line 306, in begin
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: version, status, reason = self._read_status()
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/usr/lib/python3.7/http/client.py", line 267, in _read_status
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/usr/lib/python3.7/socket.py", line 589, in readinto
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: return self._sock.recv_into(b)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/usr/lib/python3.7/ssl.py", line 1052, in recv_into
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: return self.read(nbytes, buffer)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/usr/lib/python3.7/ssl.py", line 911, in read
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: return self._sslobj.read(len, buffer)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: socket.timeout: The read operation timed out
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: During handling of the above exception, another exception occurred:
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: timeout=timeout
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 727, in urlopen
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/util/retry.py", line 410, in increment
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: raise six.reraise(type(error), error, _stacktrace)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/packages/six.py", line 735, in reraise
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: raise value
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: chunked=chunked,
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 428, in _make_request
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: self, url, "Read timed out. (read timeout=%s)" % timeout_value
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='network.satnogs.org', port=443): Read timed out. (read timeout=45)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/apscheduler/executors/base.py", line 125, in run_job
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: retval = job.func(*job.args, **job.kwargs)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/scheduler/tasks.py", line 171, in get_jobs
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: timeout=45)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/api.py", line 76, in get
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: return request('get', url, params=params, **kwargs)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/api.py", line 61, in request
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: return session.request(method=method, url=url, **kwargs)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/sessions.py", line 530, in request
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: resp = self.send(prep, **send_kwargs)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/sessions.py", line 643, in send
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: r = adapter.send(request, **kwargs)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/adapters.py", line 529, in send
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: raise ReadTimeout(e, request=request)
Jan 26 12:08:14 satnogs-fhab-1 satnogs-client[374]: requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='network.satnogs.org', port=443): Read timed out. (read timeout=45)
Jan 26 12:56:09 satnogs-fhab-1 satnogs-client[374]: Found Rafael Micro R820T tuner
Jan 26 12:56:09 satnogs-fhab-1 satnogs-client[374]: [INFO] Opening Generic RTL2832U OEM :: 00000001...
Jan 26 12:56:10 satnogs-fhab-1 satnogs-client[374]: [R82XX] PLL not locked!
Jan 26 12:56:10 satnogs-fhab-1 satnogs-client[374]: [INFO] Using format CF32.
Jan 26 12:56:10 satnogs-fhab-1 satnogs-client[374]: Allocating 15 zero-copy buffers
Jan 26 13:23:54 satnogs-fhab-1 satnogs-client[374]: Found Rafael Micro R820T tuner
Jan 26 13:23:54 satnogs-fhab-1 satnogs-client[374]: [INFO] Opening Generic RTL2832U OEM :: 00000001...
Jan 26 13:23:55 satnogs-fhab-1 satnogs-client[374]: [R82XX] PLL not locked!
Jan 26 13:23:55 satnogs-fhab-1 satnogs-client[374]: [INFO] Using format CF32.
Jan 26 13:23:55 satnogs-fhab-1 satnogs-client[374]: Allocating 15 zero-copy buffers
Jan 26 14:02:57 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 14:17:21 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 14:29:32 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 14:35:52 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 15:16:12 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 16:16:05 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 16:32:31 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 17:11:27 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 17:39:33 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 18:44:04 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 19:08:28 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 19:27:00 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 19:46:12 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 20:13:32 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 20:42:52 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 20:49:22 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 20:57:12 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 21:16:41 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 22:00:54 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 26 22:31:44 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 00:09:06 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 01:12:57 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 02:26:19 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 02:58:38 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 03:24:54 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 03:43:23 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 04:19:12 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 04:35:37 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 05:03:02 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 05:12:45 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 06:23:58 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 06:50:24 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 07:02:39 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 07:08:05 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 07:32:21 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 08:33:03 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 08:42:15 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 08:48:11 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 08:57:43 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 09:03:24 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 09:19:06 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 09:42:45 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 10:12:12 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 10:20:27 satnogs-fhab-1 satnogs-client[374]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 10:25:46 satnogs-fhab-1 systemd[1]: satnogs-client.service: Main process exited, code=killed, status=15/TERM
Jan 27 10:27:32 satnogs-fhab-1 systemd[1]: satnogs-client.service: State 'stop-final-sigterm' timed out. Killing.
Jan 27 10:27:32 satnogs-fhab-1 systemd[1]: satnogs-client.service: Killing process 10016 (satnogs_fsk.py) with signal SIGKILL.
Jan 27 10:27:32 satnogs-fhab-1 systemd[1]: satnogs-client.service: Failed with result 'timeout'.
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: rot_init called
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: dummy: _init called
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: rot_register (1)
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: rot_register (2)
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: dummy_rot_init called
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: rot_open called
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: dummy_rot_open called
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: rot_get_position called
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: dummy_rot_get_position called
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: rot_set_position called
Jan 27 10:56:51 satnogs-fhab-1 satnogs-client[13977]: dummy_rot_set_position called: 157.72 20.30
Jan 27 10:56:53 satnogs-fhab-1 satnogs-client[13977]: Found Rafael Micro R820T tuner
Jan 27 10:56:54 satnogs-fhab-1 satnogs-client[13977]: [INFO] Opening Generic RTL2832U OEM :: 00000001...
Jan 27 10:56:54 satnogs-fhab-1 satnogs-client[13977]: Found Rafael Micro R820T tuner
Jan 27 10:56:54 satnogs-fhab-1 satnogs-client[13977]: [R82XX] PLL not locked!
Jan 27 10:56:54 satnogs-fhab-1 satnogs-client[13977]: [INFO] Using format CF32.
Jan 27 10:56:54 satnogs-fhab-1 satnogs-client[13977]: Allocating 15 zero-copy buffers
Jan 27 11:14:41 satnogs-fhab-1 satnogs-client[13977]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 11:34:53 satnogs-fhab-1 satnogs-client[13977]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 11:44:19 satnogs-fhab-1 satnogs-client[13977]: satnogsclient.scheduler.tasks - ERROR - Observer job lock acquiring timed out.
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: apscheduler.executors.default - ERROR - Job "get_jobs (trigger: interval[0:01:00], next run at: 2021-01-27 12:07:34 UTC)" raised an exception
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: Traceback (most recent call last):
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 426, in _make_request
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: six.raise_from(e, None)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "<string>", line 3, in raise_from
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 421, in _make_request
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: httplib_response = conn.getresponse()
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/usr/lib/python3.7/http/client.py", line 1336, in getresponse
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: response.begin()
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/usr/lib/python3.7/http/client.py", line 306, in begin
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: version, status, reason = self._read_status()
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/usr/lib/python3.7/http/client.py", line 267, in _read_status
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/usr/lib/python3.7/socket.py", line 589, in readinto
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: return self._sock.recv_into(b)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/usr/lib/python3.7/ssl.py", line 1052, in recv_into
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: return self.read(nbytes, buffer)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/usr/lib/python3.7/ssl.py", line 911, in read
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: return self._sslobj.read(len, buffer)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: socket.timeout: The read operation timed out
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: During handling of the above exception, another exception occurred:
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: timeout=timeout
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 727, in urlopen
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/util/retry.py", line 410, in increment
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: raise six.reraise(type(error), error, _stacktrace)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/packages/six.py", line 735, in reraise
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: raise value
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: chunked=chunked,
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 428, in _make_request
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: self, url, "Read timed out. (read timeout=%s)" % timeout_value
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='network.satnogs.org', port=443): Read timed out. (read timeout=45)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/apscheduler/executors/base.py", line 125, in run_job
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: retval = job.func(*job.args, **job.kwargs)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/scheduler/tasks.py", line 171, in get_jobs
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: timeout=45)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/api.py", line 76, in get
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: return request('get', url, params=params, **kwargs)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/api.py", line 61, in request
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: return session.request(method=method, url=url, **kwargs)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/sessions.py", line 530, in request
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: resp = self.send(prep, **send_kwargs)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/sessions.py", line 643, in send
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: r = adapter.send(request, **kwargs)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: File "/var/lib/satnogs/lib/python3.7/site-packages/requests/adapters.py", line 529, in send
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: raise ReadTimeout(e, request=request)
Jan 27 12:07:25 satnogs-fhab-1 satnogs-client[13977]: requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='network.satnogs.org', port=443): Read timed out. (read timeout=45)
Network connectivity is ok
pi@satnogs-fhab-1:~ $ ping network.satnogs.org
PING srv01.libre.space (94.130.162.100) 56(84) bytes of data.
64 bytes from srv01.libre.space (94.130.162.100): icmp_seq=1 ttl=54 time=25.10 ms
64 bytes from srv01.libre.space (94.130.162.100): icmp_seq=2 ttl=54 time=23.7 ms
64 bytes from srv01.libre.space (94.130.162.100): icmp_seq=3 ttl=54 time=24.4 ms
^C
--- srv01.libre.space ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 23.699/24.706/25.977/0.948 ms
pi@satnogs-fhab-1:~ $ wget -O /dev/null 'https://network.satnogs.org'
--2021-01-27 12:31:11-- https://network.satnogs.org/
Resolving network.satnogs.org (network.satnogs.org)... 94.130.162.100, 2a01:4f8:13b:29db::1
Connecting to network.satnogs.org (network.satnogs.org)|94.130.162.100|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 6054 (5.9K) [text/html]
Saving to: â/dev/nullâ
/dev/null 100%[===========================================================================================================================================>] 5.91K --.-KB/s in 0s
2021-01-27 12:31:11 (121 MB/s) - â/dev/nullâ saved [6054/6054]
