Moved my station then it stopped working
I moved my working station (1372) from my home where it was first set up to my school. I plugged in at school and my station appeared on the SATNOGS map. When I scheduled observations, they never uploaded any waterfalls. I assume that they never occurred.
It’s likely that the new location is now behind a firewall. From reading on this forum, I see that that may be an issue for time sync with NTP. Is that the most likely issue? Should I switch services?
sudo apt install htpdate
I also read that updating security certificates? might be useful. Try this?
sudo update-ca-certificates --fresh
I am very new to this and new to Raspberry Pi as well. Thanks very much for your input.
What happens if you run manually:
curl https://network.satnogs.org
When I enter that, I get the following:
curl: (6) Could not resolve host: network.satnogs.org
It turns out I can’t ping that address either: the packets go out, but don’t come back. I suppose that explains why my station shows up on the map, but nothing happens when I schedule an observation.
I was able to use my phone as a hotspot and successfully connect, but that’s not a viable long term solution.
I believe that this is all about the security measures taken by the high school IT folks. I believe that the model is “captured portal”. I’m doing some reading about it and looking for a means to enter my login credentials from the Linux command line.
Can I install a lightweight web browser on the Pi in addition to the satnogs image or will there be some kind of conflict? I can imagine running the web browser to get logged in via the school’s captured portal model though that would all be kind of clunky.
Likely I will have to involve the IT folks in this. I am hopeful that if I give them the MAC address of the Pi, perhaps they can provide accommodation (maybe a static IP address and an open port?) I’m well beyond my comfort level here, but I’m hoping that I know what to ask when I speak with the IT folks.
Thanks again and all guidance is very much appreciated!
In the past I have succesfully managed to login into captive portals from command line in a RPi by installing manually lynx (command line browser).
This shows you don’t even have public DNS (name service). The IP is 94.130.162.100. Can you even run:
curl https://nasa.gov
