Dear all,
Could you suggest how I should mount TA-1 Turnstile and Winkler Turnstile antenna to the mast?
Can I have both antennas together on a single mast or should I have each antenna on a separate mast?
I have buyed two RTLSDR wideband LNA and two Bandstop filter, so is it okay to use them permanently mounted and connected to the antenna inside weatherproof enclosure or should I use a portable lightweight mast and connect them only while receiving?
Considering the climate in Finland, could you suggest how I should proceed in mounting?
Would be happy if I get some valuable suggestions.
Sorry for the late answer. The manual of the TA-1 says: Stay away at least 2-Meters from metallic material. For testing i removed everything and mounted the TA-1 on top. Only one dipole leg is ending there.
I am awaiting my Winkler crossed dipole for 435 MHz. So I plan to mount it with a sidearm or on the running rail.
Have a look at my setup report. My actual groundstation is also linked there:
