Hi. We are setting up a new station. We have a satnogs rotator controller v2. Its a pure satnogs build image_2020-03-04-Raspbian-SatNOGS-lite
If I do: sudo rotctl -m 204 -s 19200 -r /dev/ttyUSB0 -vvvvv
and rotator command: P 020 020 - the motors move ok
I set up a pass [Observation 2225317] in https://network.satnogs.org/observations/ and got the pending screen ok, but at the time of the pass the motors do not move. Any ideas anyone?
After the pass I get:
sudo systemctl status satnogs-client
â—Ź satnogs-client.service - SatNOGS client
Active: active (running) since Sat 2020-05-16 15:34:06 CEST; 1h 1min ago
Main PID: 1021 (satnogs-client)
Tasks: 22 (limit: 2200)
Memory: 126.5M
└─1021 /var/lib/satnogs/bin/python3 /var/lib/satnogs/bin/satnogs-client
May 16 15:53:23 raspberrypi satnogs-client[1021]: dummy_rot_open called
May 16 15:53:23 raspberrypi satnogs-client[1021]: rot_get_position called
May 16 15:53:23 raspberrypi satnogs-client[1021]: dummy_rot_get_position called
May 16 15:53:23 raspberrypi satnogs-client[1021]: rot_set_position called
May 16 15:53:30 raspberrypi satnogs-client[1021]: Found Rafael Micro R820T tuner
May 16 15:53:31 raspberrypi satnogs-client[1021]: Found Rafael Micro R820T tuner
May 16 15:53:31 raspberrypi satnogs-client[1021]: [R82XX] PLL not locked!
May 16 15:53:31 raspberrypi satnogs-client[1021]: [INFO] Using format CF32.
May 16 15:53:32 raspberrypi satnogs-client[1021]: Allocating 15 zero-copy buffers
May 16 15:58:57 raspberrypi satnogs-client[1021]: 4
“versions”: {
“satnogs-client”: “1.3.1”,
“satnogs-client-ansible”: “202004031132”,
“gr-satnogs”: “2.1.2-1”,
“gr-soapy”: “2.1.3-1”,
“gnuradio”: “3.8.1.0~rc1-2”,
“satnogs-config”: “0.10.1”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “4.19.97-v7+”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 971059200,
“available”: 763920384,
“percent”: 21.3,
“used”: 139444224,
“free”: 442736640,
“active”: 237924352,
“inactive”: 213671936,
“buffers”: 30519296,
“cached”: 358359040,
“shared”: 6561792,
“slab”: 56553472
“disk”: {
“total”: 29424611328,
“used”: 3774439424,
“free”: 24407347200,
“percent”: 13.4
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_station_elev”: “180”,
“satnogs_station_id”: “1312”,
“satnogs_station_lat”: “49.872”,
“satnogs_station_lon”: “8.622”
Regards
Mark
