I am currently in the process of setting up my SATNOGS station and have a question about how to schedule METEOR M2 (and M 2-2) recordings.
When I schedule a recording, the system appears to only record data at ~50kHz. The LRPT downlink is at 80kbps so this is not an adequate record bandwidth. Other stations (that successfully decode METEOR LRPT) record at ~140kHz by the looks of it (see example below).
I am currently running the client version 0.9 (as packaged with the raspberry pi image) with a RTLSDR.
It looks like the example above is running a dev branch of the client (1.0.dev+120.g886bf4b.dirty), do I need to upgrade to a dev branch to support automated METEOR decoding? Am I able to do this easily from Ansible on the raspi? Do we know how stable these branches are at the moment?
Thanks, I shall follow those instructions - I was secretly hoping that it had been automatically built in to a later version or something so I could be lazy…
I spent today tinkering with the setup and finally have it working! My advice if you are going to implement this is to always folder check permissions! (This caught me out a few times)
