Magnetic end stop
I would like to use magnetic limit switches in place of mechanical end stops whose blade is blocked regularly.
I tried the sensor: https://produktinfo.conrad.com/datenblaetter/500000-524999/503655-da-01-en-HALLSENSOR_55100_3H_02_A.pdf
But it did not seem to work.
Can someone help me?
If not, what has someone been using as a sensor?
Regards
Manu
That sensor is a Hall effect device.
Did you use a pull up resistor with it?
What are you interfacing to?
Would you rather use a reed switch? (Two wire magnetic dry contact).
Hello,
Thank you for the answer and forgiveness for the delay!
I have come a long way and I think I have solved my problems.
First of all I modified the file endstop.h:
I replaced
pinMode (_pin, INPUT);
by
pinMode (_pin, INPUT_PULLUP);
In addition I remember (I’m a beginner!) It was necessary to put the magnet in a certain direction for the sensor to work. For that I used the program:
int pinSensor = 4;
void setup () {
  • pinMode (pinSensor, INPUT_PULLUP);*
  • Serial.begin (9600);*
void loop () {
  • int capt = digitalRead (pinSensor);*
  • Serial.println (capt); // Acrit 1 or 0*
  • if (capt == HIGH) {*
  • Serial.println ("HIGH SENSOR");*
  • else {*
  • Serial.println ("LOW SENSOR");*
This allows me to check the state of the sensor and the direction of the magnet.
The magnet and the sensor were stuck on the rotator
Regards
Manu
Hey! Nice work!
I just look into the satnogs-rotator-firmware and the pin is defined with internal pull up. Which repository are you using?
Exact!!!
it is a mistake!
I did a lot of tests and I had to modify the file, sorry!
I take this opportunity to ask you advice, I would like to realize this antenna:
I could have your opinion? What about the RHCP with this type of editing?
Manu
