Hello
I am new here and it’s my first post, so I will introduce myself a little - I’m Joanna from Grenoble, I’m working for Cube Sat students project at University, I’m developing ground station.
I have Kenwood Ts 2000 and Yaesu G5500. I’m running all software on Linux. I installed rotctld and rigctld and gpredcit. So the problem is that first when I installed all on my personal laptop LVB tracker was working perfectly, with console and with gpredict as well ( I was using USB adapter for connection) but now when its on PC and connected by serial link elevation stop working - when I try to set position by console it is not always working well as well too. When I use P command and set position I have to type p again to make rotator work (before it was working immediately). I calibrated it again, but nothing helped. This is CCW north stop rotator ( Az 0-450 ; El 0-180). I have no idea what can be a problem. I will really appreciate any help, because it is really hard to find something about it.
I don’t know a lot about programming micro controllers, so I don’t know if it will helps but its FoxDelta ST2-090709.
Have a good day !
Joanna
!! wow thank you so much
