Lucky-7 is getting closer to re-entry (~7-10 days), let’s try to track it.
Updated TLE based on latest from space-track.org and latest Network observations:
LUCKY-7
1 44406U 24350.75000000 .00000000 00000-0 12152-2 0 00
2 44406 97.6742 4.8683 0004423 135.9269 356.4699 16.28959761 08
lucky_350_v1.dat (1.4 KB)
sites.txt (9.8 KB)
A small correction in accuracy of the above TLE:
LUCKY-7
1 44406U 24350.80000000 .00000000 00000-0 12152-2 0 06
2 44406 97.6742 4.7580 0004124 142.0985 283.4138 16.29438656 08
One more small correction:
LUCKY-7
1 44406U 24350.90000000 .00000000 00000-0 12523-2 0 09
2 44406 97.6742 5.1278 0004398 126.9794 164.9403 16.30595202 00
sites.txt (9.8 KB)
lucky_350_v5.dat (560 Bytes)
One more TLE update:
LUCKY-7
1 44406U 24351.20000000 .00000000 00000-0 11925-2 0 08
2 44406 97.6742 5.5563 0004675 105.1528 148.8410 16.35168689 02
lucky_351_v1.dat (1.2 KB)
sites.txt (9.8 KB)
A small fix for the previous TLE:
LUCKY-7
1 44406U 24351.30000000 .00000000 00000-0 12019-2 0 04
2 44406 97.6742 5.8650 0003380 111.1037 11.4104 16.36559843 08
sites.txt (9.8 KB)
lucky_351_v3.dat (840 Bytes)
One more TLE update based on the latest observations:
LUCKY-7
1 44406U 24351.37000000 .00000000 00000-0 12019-2 0 01
2 44406 97.6742 5.6487 0004553 111.0718 63.7924 16.38491124 01
lucky_351_v5.dat (1.2 KB)
sites.txt (9.8 KB)
Updated TLE based on observations from pass over Australia:
LUCKY-7
1 44406U 24351.40000000 .00000000 00000-0 13117-2 0 05
2 44406 97.6742 5.6964 0004234 105.5607 246.3355 16.40471519 08
sites.txt (9.8 KB)
lucky_351_v7.dat (805 Bytes)
One more adjustment:
LUCKY-7
1 44406U 24351.41000000 .00000000 00000-0 13117-2 0 06
2 44406 97.6742 5.7189 0004011 114.3819 296.3643 16.39048804 04
lucky_351_v10.dat (1.1 KB)
sites.txt (9.8 KB)
One more update:
LUCKY-7
2 44406 97.6742 5.5935 0004011 114.3819 295.8988 16.39767842 07
sites.txt (9.8 KB)
lucky_351_v14.dat (525 Bytes)
Probably one of the last TLE updates:
LUCKY-7
1 44406U 24351.63000000 .00000000 00000-0 71786-3 0 07
2 44406 97.6684 5.9443 0006976 212.9930 57.8116 16.46049087 02
One adjustment on the previous TLE:
LUCKY-7
1 44406U 24351.65000000 .00000000 00000-0 53972-3 0 06
2 44406 97.6684 6.3401 0003565 250.3039 139.1797 16.52426135 07
lucky_351_v22.dat (1015 Bytes)
sites.txt (9.8 KB)
Not perfect much but it should work:
LUCKY-7
1 44406U 24351.70000000 .00000000 00000-0 26970-3 0 00
2 44406 97.6684 6.4170 0005601 225.7302 100.8259 16.53633299 03
sites.txt (9.8 KB)
lucky_351_v23.dat (1.8 KB)
Probably the last one:
LUCKY-7
1 44406U 24351.72000000 .00000000 00000-0 27008-3 0 05
2 44406 97.6684 6.9505 0006699 227.3317 218.3730 16.56977421 02
lucky_351_v25.dat (1.9 KB)
sites.txt (9.8 KB)
It looks like that Lucky-7 has now been re-entered.
Last reception:
SatNOGS Network - Observation 10775057 by Station 2937 - WH6GVF UHF
Last data:
SatNOGS Network - Observation 10775131 by Station 1888 - SA2KNG Experimental
Acording to some sorces i found its still in orbit but may not be operational n2yo still has a low altitude but still tracking a python program to predict reentry says it has a tiny bit left to live. === Step 1: Collecting Tracking Data ===
Collecting CubeSat data every 10 seconds…
Time: 2024-12-17T07:05:17Z | Altitude: 141.76 km | Velocity: 7824.79 m/s
Time: 2024-12-17T07:06:17Z | Altitude: 142.64 km | Velocity: 7824.00 m/s
Time: 2024-12-17T07:07:17Z | Altitude: 143.36 km | Velocity: 7823.28 m/s
Time: 2024-12-17T07:08:17Z | Altitude: 143.90 km | Velocity: 7822.64 m/s
Time: 2024-12-17T07:09:17Z | Altitude: 144.26 km | Velocity: 7822.08 m/s
Time: 2024-12-17T07:10:17Z | Altitude: 144.44 km | Velocity: 7821.60 m/s
Time: 2024-12-17T07:11:17Z | Altitude: 144.44 km | Velocity: 7821.20 m/s
Time: 2024-12-17T07:12:17Z | Altitude: 144.28 km | Velocity: 7820.88 m/s
Time: 2024-12-17T07:13:17Z | Altitude: 143.96 km | Velocity: 7820.64 m/s
Time: 2024-12-17T07:14:17Z | Altitude: 143.50 km | Velocity: 7820.47 m/s
Time: 2024-12-17T07:15:17Z | Altitude: 142.91 km | Velocity: 7820.37 m/s
Time: 2024-12-17T07:16:17Z | Altitude: 142.21 km | Velocity: 7820.33 m/s
Time: 2024-12-17T07:17:17Z | Altitude: 141.43 km | Velocity: 7820.35 m/s
Time: 2024-12-17T07:18:17Z | Altitude: 140.58 km | Velocity: 7820.40 m/s
Time: 2024-12-17T07:19:17Z | Altitude: 139.69 km | Velocity: 7820.50 m/s
Data Collection Complete:
Average Altitude: 142.82 km ± 1560.99 m
Average Velocity: 7821.45 m/s ± 1.31 m/s
=== Step 2: Predicting Reentry ===
Predicted reentry in approximately 71.61 minutes.
[Program finished]
Hi @cn64 and welcome in the Community!
A quick comment on your post to have in mind based on my experience with tracking re-entries.
The re-entry calculations and satellite tracking maps depend on the available TLE sets. Given that a TLE set (the orbit actually) during the re-entry changes fast and sometimes when published is already deprecated, there is a chance to show that a satellite is in orbit when it is not.
if you are interested I can write some more details and give a couple of examples. Also there is this BEESAT-9 re-entry analysis that can give you an idea on the accuracy of the orbital data as it compares some orbital parameters calculated from space-track TLEs, SatNOGS Community TLEs and GNSS data from the satellite.
This is the last observation I had scheduled for 0633 this morning 24.12.17 UTC
https://network.satnogs.org/observations/10775321/
I did receive a signal which I believe is lucky-7 based on my other observations.
Unfortunately this doesn’t seem to be the satellite, these are some points that makes me doubt:
- The peaks of the signal are too far from each other, below in the image in the same scale, at the top is the signal from your observation and at the bottom signal from observation 10775267:
In the image above, we can also notice that we miss from the signal you observed the rest of the peaks, which should be visible given the power of the received signal.
Finally the observation was scheduled with older TLE set which wasn’t accurate at the observation time, in this case (re-entry one) we expect the satellite signal to show up earlier than what TLE describe. So, I would expect the signal to be at the beginning (at the bottom) of the observation and not at the end.
Based on the above, I’m 99.9% sure that the signal doesn’t belong to lucky-7, and given its power it is probably something terrestrial.
