Hello all,
Does anyone use a Lime mini with satnogs. ?
My problem is that I have no waterfall after reception
Attached my parameters for comparison.
Thanks for your help.
“versions”: {
“satnogs-client”: “1.3.4”,
“satnogs-client-ansible”: “202007160921”,
“satnogs-flowgraphs”: “1.2.2-1”,
“gr-satnogs”: “2.1.2.1-1”,
“gr-soapy”: “2.1.3-1”,
“gnuradio”: “3.8.1.0~rc1-2”,
“satnogs-config”: “0.10.2”
“state”: {
“is-applied”: false,
“pending-tags”: [
“satnogs_client_config”
“system”: {
“date”: “2020-08-03T08:26:35.878624+00:00”,
“distribution”: {
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Raspbian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “raspberrypi”,
“release”: “4.19.97-v7+”,
“machine”: “armv7l”,
“processor”: “”
“memory”: {
“total”: 971055104,
“available”: 702464000,
“percent”: 27.7,
“used”: 162799616,
“free”: 248741888,
“active”: 303886336,
“inactive”: 280641536,
“buffers”: 73580544,
“cached”: 485933056,
“shared”: 38838272,
“slab”: 100921344
“disk”: {
“total”: 15347310592,
“used”: 8137330688,
“free”: 6498869248,
“percent”: 55.6
“configuration”: {
“satnogs_antenna”: “LNAW”,
“satnogs_gain_mode”: “Settings Field”,
“satnogs_other_settings”: “TIA=12,PGA=0,LNA=12”,
“satnogs_ppm_error”: “42”,
“satnogs_rf_gain”: “20”,
“satnogs_soapy_rx_device”: “driver=lime”,
“satnogs_station_elev”: “612”,
“satnogs_station_id”: “120”,
“satnogs_station_lat”: “42.817”,
“satnogs_station_lon”: “1.584”
