Launch of "REAL" satellite, 2025-07-23 18:13 UTC
Until identification we use the temporary NORAD ID, however if someone send data with the candidate NORAD ID then we create a suggestion for this NORAD ID and we gather/keep the data. In this case here is the entry SatNOGS DB - New Satellite so @sv2hwm probably you will find there the data.
Later when the identification process is done, the two satellite entries will be merged and data from both entries will be available.
Thank you Fredy. Indeed, my uploaded data is there. @PE0SAT
A post was split to a new topic: YUBELEINY 2 and COSMOS 2491
64869 might be LIDE on 2235 MHz
confirmed and added 2026-01-24 to DB
PEXT or 64874 possibly on 2235 MHz
and confirmed in next pass
