Hey @cgbsat:
I saw that you’re using a L band antenna. Can you show some results?
Hey @cgbsat:
It’s not an L-band antenna that I’m using but S-band instead. The antenna, a 3.5 turn helix, and the G4DDK preamp are tuned to 2250MHz. Back in April, Pierros and I did some experiments with the TT&C beacons of the CartoSAT satellites, and the observations are in the database. The best examples are below, where you can see the TT&C beacon. The broad curved signal is the DC offset, as the 100kHz LO offset is not sufficient to keep the DC curve out of the observing window.
https://network.satnogs.org/observations/114223/
https://network.satnogs.org/observations/113942/
https://network.satnogs.org/observations/113944/
https://network.satnogs.org/observations/113941/
Interesting. Thank you for the informations. What kind of RX did you used at this time?
