But they seem to get removed shortly after a pass.
I’d like to keep some of these files to ‘play with’. Do they get archived anywhere temporarily, or just deleted. Can I change this in the config? I’m currently having to babysit a pass and copy them quickly!
receiving*.out file is a partial ogg file.
receiving*.dat file is a structured waterfall data file that we use to plot the png image.
The ogg file and the png file are uploaded to the network, if you want to keep a copy of them locally you can set in “Advanced —> Path settings —> SATNOGS_COMPLETE_OUTPUT_PATH” on where you want to move files after uploading.
For keeping the receiving*.dat file you need to set “Advanced —> Path settings —> SATNOGS_REMOVE_RAW_FILES” to False.
Keep in mind that files in /tmp are saved in memory, which means you need to transfer them continuously to avoid a full memory. On the other hand it is not suggested to write these files on the sd-card as many reads/writes can quickly make it unusable. Maybe transfer them over ssh or plug a usb stick or an external hard disk are better solutions.
Ah, I hadn’t twigged /tmp was in RAM. Cheers. I wanted a before and after snapshot of my station before I added an LNA but it seems I’ve killed the sensitivity that much a recording doesn’t really matter now! Gonna have to traipse up the loft again tomorrow and figure out what’s up, check the connections, remove the FM band stop filter and play a little more.
