Kakushin Rising mission (JAXA Rideshare) - electron - 2026-04-23 03:09 UTC
14:03:39 UTC Waterfall capture showing CW beacon signals from
  • ARICA-2
  • Magnaro-II Piscis
  • WASEDA-SAT-ZERO-II
  • FSI-SAT2
  • OrigamiSat-2
FSI-SAT2 TLE update:
FSI-SAT2
1 98326U 27001A   26113.47437430  .00000000  00000-0  29290-3 0    01
2 98326  97.5133 264.6135 0010953 206.3608  57.8527 15.06050055    09
@sv2hwm and to others too, do you see any other signal except CW?
I’m wondering if the FSK etc modes are disabled or maybe only enabled over Japan.
TLE update for WASEDA-SAT-ZERO-II:
WASEDA-SAT-ZERO-II
1 98327U 27001A   26113.43557554  .00000000  00000-0  30050-3 0    04
2 98327  97.5133 264.0976 0010953 206.3608 209.1238 15.07979387    07
waseda2_113_v1.dat (560 Bytes)
sites.txt (13.2 KB)
Last but not least (unfortunately no signal from KOSEN-2R), an updated TLE for ARICA-2:
ARICA-2
1 98329U 27001A   26113.71443610  .00000000  00000-0  29916-3 0    03
2 98329  97.5133 264.2063 0010953 206.3608 281.8662 15.08387874    01
sites.txt (13.3 KB)
arica2_113_v1.dat (1.4 KB)
Excellent signal received from the newly launched OrigamiSat-2 during a pass over Brazil :brazil: !!
The MAGNARO-II - Piscis, ARICA-2 and FSI-SAT2 were also successfully received :grin:
Space track is already sharing TLE for Cospar 2026-088
I have a match for object 68798 on 436.325 - MAGNARO-II - Piscis
Another match for object 68796 on 436.830 - ARICA-2
Another match for object 68792 on 437.175 - FSI-SAT2
Only one pass active, so there is room for error.
Another match for object 68797 on 437.200 - WASEDA-SAT-ZERO-II
ARICA2
2026-04-23T13:56:29 2fde070cc293201b
2026-04-23T13:57:07 00ddd1d2d000
2026-04-23T14:00:42 cqcq de js1ysd arica2
2026-04-23T14:01:19 2fde070cc2c7401b
2026-04-23T15:28:31 00f6afd2b100
2026-04-23T15:29:06 a85742b0c560eb
2026-04-23T15:29:44 cqcq de js1ysd arica2
2026-04-23T15:30:20 2fde070cca97401b
2026-04-23T15:30:58 00f751d2b100
2026-04-23T15:31:33 a7d742b0c698eb
2026-04-23T15:32:08 cqcq de js1ysd arica2
2026-04-23T15:32:45 2fde070cc91b401b
2026-04-23T15:33:23 00f7e9d2b100
2026-04-23T15:34:33 cqcq de js1ysd arica2
2026-04-23T15:35:09 2fde070cc09b401b
2026-04-23T15:35:47 00f876d2b100
2026-04-23T15:36:25 a85742b0c638eb
2026-04-23T15:37:00 cqcq de js1ysd arica2
2026-04-23T15:37:37 2fde070cc19b201b
2026-04-23T15:38:15 00f923d2b100
2026-04-23T15:38:51 a7d742afc590ec
Another match for object 68795 on 437.505 - OrigamiSat-2
ORIGAMI-2
2026-04-23T17:06:11 js1yru origami2 068079ca851e016d7e79900000000083840300c160d0f54b42483e02
2026-04-23T17:07:28 js1yru origami2 06807c0e741e01727377900000000084840300c160d1424b42483e02
OrigamiSat-2
2026-APR-23 19:50:06 UTC:
JS1YRU ORIGAMI2 06 7E 87 2E 81 00 01 7C 6F 78 90 1A 00 00 00 81 83 04 00 C1 60 F7 60 4B 42 48 3E 02
ARICA-2
2026-APR-23 19:49 UTC: 5FDE070CC91F201B
2026-APR-23 19:49 UTC: 013C0488B900
2026-APR-23 19:50 UTC: AA7744ACF4F8E1
2026-APR-23 19:51 UTC: CQCQ DE JS1YSD ARICA2
2026-APR-23 19:51 UTC: 5FDE070CC197201B
2026-APR-23 19:52 UTC: 013CA289B900
2026-APR-23 19:52 UTC: A9F744ADF6C8E1
2026-APR-23 19:53 UTC: CQCQ DE JS1YSD ARICA2
MAGNARO-II - Piscis
2026-APR-23 19:51:49 UTC:
JJ2YXG MAGNARO-P 7F6F710100000203 1100751082E0
FSI-SAT2
2026-APR-23 19:50:41 UTC:
0 JS1YQU FSISAT 0 3.56V -0.32A 6.38D TTTEEEEEEEEE
Looking at the posts here and with a spot-check of the SatNogs observations thus far, it appears that KOSEN-2R has not been heard. Does that sound correct? Has anyone seen anything about its status?
The KOSEN-2R operations team states that the satellite does not use the amateur radio band.
On the other hand, based on the API/A (Advance Publication Information) submitted to the ITU, the downlink frequency can be interpreted as falling within the range of 465.3245 MHz to 465.3955 MHz.
Further careful verification may be required to reconcile these pieces of information.
(KOSEN-2R team’s post)
Using the antenna at the KOSEN-1 satellite ground station, we have just successfully received the beacon signal (CW at 436.830 MHz) from the “ARICA-2 satellite.” Congratulations, Professor Sakamoto! (Since the KOSEN-2R satellite does not use amateur radio frequencies, we will need to verify its signal later.)
(Translated by DeepL)
(ITU API/A document)
Oh! Well that’s very helpful. Looking at their IARU coordination page, it appeared that after initially being denied, they made changes and ultimately received coordination for 436.750.
https://iaru.amsat-uk.org/formal_detail.php?serialnum=820
If they ultimately used something up at 465 MHz, then that’s worth looking for!
Thanks for the info.
Ok, I thought I had previously checked ITU for info on all these sats, but I must have neglected KOSEN-2R after seeing the IARU coordination.
But sure enough, there is only one downlink freq listed:
… and that 71 kHz bandwitch sure sounds like it might be 62k5 LoRa (+ doppler). So, when the orbit cycles around to be high enough in my sky, I’ll see if there are any signals on 465.36.
Thanks again for replying.
I have recorded a packet of ARICA-2, but have not decoded it, because it looks damaged. The link to the IQ file is attached.
Thanks for sharing your I/Q file. Nothing wrong w/ the file itself; near the beginning there is well-formed data burst.
… but it might be a little weak to decode. I’ve tried several times & no luck yet. Someone w/ more skill in that area might be successful.
Of course there is a lot of CW in the recording as well; I’ve not tried to decode any of that. Just visually looking in Inspectrum, we might need just a little bit more SNR to decode.
Congrats on the reception!
