Jielong-3 - CAMSAT CAS-5A - 2022-12-09 06:35 UTC
Great job on the decoder! Those counts of stored images from each camera (18, 14, & 17) agree with what I calculated manually from a recent packet on SatNogs last night →
https://twitter.com/scott23192/status/1628301922657619969
… however, as mentioned above, the satellite was stuck in a constant-carrier downlink. So, until that gets fixed, we have no telemetry or chance to download any of those stored images.
XW-3 (CAS-9) already 2 months in the same condition :frowning:
CAS-5A is active now !
The satellite is working. I just sent to it two DTMF requests for images of the first and second. And the satellite started sending data !
I sent a DTMF request one more time for photo1 x2 & photo2 x2
The satellite also responds to my DTMF command *A01# …
The satellite has 3 cameras.
Access to the directory is *ABC#.
Maybe I will also try the *C01# command :slight_smile:
According to the manual, there are a total of -60- locations for pictures to be stored (from all cameras combined). The only downlink commands mentioned are *B–# (where the slot requested is from 01 to 60).
… I would be reluctant to experiment with any undocumented commands unless you have info from the Project Team that is not in the manual.
You’re probably right in your reluctance.
I have too much respect for you to disregard your words.
Best regards :slight_smile:
This is the same camera but with including frame sequence numbers.
Hello,
Attached is CAMSAT CAS-5A Amateur Radio Satellite User’s Manual V2.1, for your reference.
Alan, BA1DU
CAMSAT
CAMSAT CAS-5A Amateur Radio Satellite User’s Manual V2.1.pdf (1.8 MB)
Comparing both manuals it seems to me that this detailed section was not there
It was not. Honestly it looks like it has been added just after request.
I am not claiming evidence :wink:
I sent around 01:19 requesting photo number 7 x2 including frame
sequence numbers. *A07# .
I see there were some observations on satnogs.
Maybe we can put together one photo of them.
With decodes from -2- passes received mostly by N6RFM plus some from my own location, a 100% complete JPG image (#6) was assembled! Unfortunate that it’s not one of the ‘nice’ pictures, but it was great to use the sequence numbers to put together a JPG with no missing packets.
WOW !
Who else could have solved it first :wink:
Can you explain the methodology in detail ? Apart from the photo which explains what the next bytes of information mean.
Indeed, @K4KDR What are the bytes before the image data? The usual stuff?
By the way, could you please send IQ/KISS of the dump and of the photo catalog as well ?
Good pass over Europe. IQ file. photo 7 & 9
