It's time to upgrade the software of your stations
[edit] oops, skipped a step. Lemme try again.
Nope - can’t get it to work, but I’m sure I don’t know how to change my cron job to include that line… here is my cron job, what do I change to implement that environment?
0 0 * * * /home/pi/autosked/gitclone/satnogs-auto-scheduler/schedule_single_station.py -s 272 -d 47 -z -P /home/pi/autosked/gitclone/satnogs-auto-scheduler/iss_272.txt -f
The environment was created here:
/autosked/gitclone/satnogs-auto-scheduler/scheduler_env
Thanks for the help, this is new stuff for me.
–Roy
K3RLD
Ground station 715 updated from stretch to buster (after an update to enable ‘SATNOGS_SETUP_RELEASE_UPGRADE_ENABLED’).
Apologies Dimitris. Observation #1393477 got kicked due to updating…
If I have any major issues I will report back…
Michael
How does that work with a cronjob?
Dec 18 17:09:42 satnogs1 systemd[359]: satnogs-client.service: Failed to execute command: No such file or directory
Dec 18 17:09:42 satnogs1 systemd[359]: satnogs-client.service: Failed at step EXEC spawning /var/lib/satnogs/bin/satnogs-client: No such file or directory
Dec 18 17:09:42 satnogs1 systemd[1]: satnogs-client.service: Main process exited, code=exited, status=203/EXEC
Dec 18 17:09:42 satnogs1 systemd[1]: satnogs-client.service: Failed with result 'exit-code'.
Dec 18 17:09:42 satnogs1 systemd[1]: satnogs-client.service: Service RestartSec=100ms expired, scheduling restart.
Dec 18 17:09:42 satnogs1 systemd[1]: satnogs-client.service: Scheduled restart job, restart counter is at 5.
Dec 18 17:09:42 satnogs1 systemd[1]: Stopped SatNOGS client.
Dec 18 17:09:42 satnogs1 systemd[1]: satnogs-client.service: Start request repeated too quickly.
Dec 18 17:09:42 satnogs1 systemd[1]: Failed to start SatNOGS client.
Well that didn’t go to well :frowning:
We’ll fix it :slight_smile:
Describe the process you followed, step by step.
By calling the interpreter in the virtualenv and providing the script as command line argument you can execute the script in the virtualenv within a non-interactive session like cron.
Derived from your example:
0 0 * * * /autosked/gitclone/satnogs-auto-scheduler/scheduler_env/bin/python /home/pi/autosked/gitclone/satnogs-auto-scheduler/schedule_single_station.py -s 272 -d 47 -z -P /home/pi/autosked/gitclone/satnogs-auto-scheduler/iss_272.txt -f
This should also answer your question, @DL4PD?
I’ll attempt this tonight. The whole station is down and I tried SSH’ing in but no connection.
In other news, the other stations Autoscheduling seems wonky, too. I’ll have to do more digging there.
  1. sudo satnogs-setup
  2. Update
  3. Apply
  4. Reboot
  5. Update
  6. Upgrade
  7. Apply
Then tested with a final reboot when I saw the errors in the log. No change.
From the wiki:
To update SatNOGS software, including the configuration tool itself:
  1. SSH into the system and (re-)run sudo satnogs-setup ; this will bring up the configuration menu
  2. Select Upgrade to upgrade all distribution packages to the latest; this may require a reboot. If this option is not available, running an Update will make it show up
  3. Select Update to update the configuration tool
  4. Select Apply and the Raspberry Pi will update itself; this may take some time
  5. Before exit, check at the top that you have the latest satnogs-client and gr-satnogs versions
  6. Select Back to exit
That would be:
  2. Update
  3. Upgrade
  4. Reboot
  5. Update
  6. Apply
Performed these steps again specifically and still having same error.
Dec 19 11:35:36 satnogs1 systemd[359]: satnogs-client.service: Failed to execute command: No such file or directory
Dec 19 11:35:36 satnogs1 systemd[359]: satnogs-client.service: Failed at step EXEC spawning /var/lib/satnogs/bin/satnogs-client: No such file or directory
Dec 19 11:35:36 satnogs1 systemd[1]: satnogs-client.service: Main process exited, code=exited, status=203/EXEC
Dec 19 11:35:36 satnogs1 systemd[1]: satnogs-client.service: Failed with result 'exit-code'.
Dec 19 11:35:36 satnogs1 systemd[1]: satnogs-client.service: Service RestartSec=100ms expired, scheduling restart.
Dec 19 11:35:36 satnogs1 systemd[1]: satnogs-client.service: Scheduled restart job, restart counter is at 5.
Dec 19 11:35:36 satnogs1 systemd[1]: Stopped SatNOGS client.
Dec 19 11:35:36 satnogs1 systemd[1]: satnogs-client.service: Start request repeated too quickly.
Dec 19 11:35:36 satnogs1 systemd[1]: Failed to start SatNOGS client.
pi@satnogs1:~ $ ls -l /var/lib/satnogs/bin/
total 3040
-rw-r--r-- 1 satnogs satnogs    2075 Sep 17 04:08 activate
-rw-r--r-- 1 satnogs satnogs    1017 Sep 17 04:08 activate.csh
-rw-r--r-- 1 satnogs satnogs    2171 Sep 17 04:08 activate.fish
-rw-r--r-- 1 satnogs satnogs    1137 Sep 17 04:08 activate_this.py
-rwxr-xr-x 1 satnogs satnogs     222 Oct 22 00:44 dotenv
-rwxr-xr-x 1 satnogs satnogs     245 Sep 17 04:08 easy_install
-rwxr-xr-x 1 satnogs satnogs     245 Sep 17 04:08 easy_install-2.7
-rwxr-xr-x 1 satnogs satnogs     223 Sep 17 04:08 flask
-rwxr-xr-x 1 satnogs satnogs   35110 Sep 17 04:08 miniterm.py
-rw-r--r-- 1 satnogs satnogs   36151 Sep 17 04:08 miniterm.pyc
-rwxr-xr-x 1 satnogs satnogs     227 Sep 17 04:08 pip
-rwxr-xr-x 1 satnogs satnogs     227 Sep 17 04:08 pip2
-rwxr-xr-x 1 satnogs satnogs     227 Sep 17 04:08 pip2.7
lrwxrwxrwx 1 satnogs satnogs       7 Sep 17 04:07 python -> python2
-rwxr-xr-x 1 satnogs satnogs 2984816 Sep 17 04:07 python2
lrwxrwxrwx 1 satnogs satnogs       7 Sep 17 04:07 python2.7 -> python2
-rwxr-xr-x 1 satnogs satnogs    2334 Sep 17 04:08 python-config
-rwxr-xr-x 1 satnogs satnogs     223 Sep 17 04:08 wheel
Can you paste your configuration (without the API key) as returned by Show dialog?
│ disable_decoded_data: false
│ gpsd_enabled: false
│ hamlib_utils_rig_enabled: false
│ satnogs_api_token: ***snip***
│ satnogs_dev_args: airspy,bias=1
│ satnogs_rf_gain: 30
│ satnogs_rx_device: airspymini
│ satnogs_station_elev: 1004
│ satnogs_station_id: 1003
│ satnogs_station_lat: ***snip***
│ satnogs_station_lon: ***snip***
│ snmpd_enabled: true
Have you ever installed satnogs-client using pip on the system?
Potentially. I did test out the satnogs-client when it was in beta before in Ansible but reverted later.
That could be it. Try pip uninstall satnogsclient or/and pip uninstall satnogs-client. Also, does Ansible show any error when you hit Apply?
This didn’t work at all, but if I add /home/pi before the first part, I get this:
2019-12-19 21:51:15,294 - root - INFO - Requesting information for ground station 272
2019-12-19 21:51:16,962 - root - INFO - Ground station information retrieved!
2019-12-19 21:51:16,965 - root - INFO - Updating transmitters and TLEs for station
2019-12-19 21:51:16,967 - root - INFO - Fetching transmitter information from DB.
2019-12-19 21:51:21,043 - root - INFO - Transmitters received!
2019-12-19 21:51:21,110 - root - INFO - Transmitters filtered based on ground station capability.
2019-12-19 21:51:21,112 - root - INFO - Fetching transmitter information from DB.
2019-12-19 21:51:29,119 - root - INFO - Transmitters received!
2019-12-19 21:51:29,185 - root - INFO - Transmitters filtered based on ground station capability.
2019-12-19 21:51:29,187 - root - INFO - Fetching satellite information from DB.
2019-12-19 21:51:30,337 - root - INFO - Satellites received!
2019-12-19 21:51:30,355 - root - INFO - Requesting transmitter success rates.
2019-12-19 21:52:08,321 - root - INFO - Transmitter success rates received!
2019-12-19 21:52:08,323 - root - INFO - Fetch from http://mstl.atl.calpoly.edu/~ops/keps/kepler.txt
2019-12-19 21:52:08,768 - root - INFO - Fetch from https://www.amsat.org/amsat/ftp/keps/current/nasabare.txt
  File "/home/pi/autosked/gitclone/satnogs-auto-scheduler/schedule_single_station.py", line 395, in <module>
    main()
  File "/home/pi/autosked/gitclone/satnogs-auto-scheduler/schedule_single_station.py", line 246, in main
    tles = fetch_tles(norad_cat_ids)
  File "/home/pi/autosked/gitclone/satnogs-auto-scheduler/scheduler_env/lib/python3.7/site-packages/satellite_tle/fetch_tles.py", line 53, in fetch_tles
    new_tles = fetch_tles_from_url(url=url, verify=verify)
  File "/home/pi/autosked/gitclone/satnogs-auto-scheduler/scheduler_env/lib/python3.7/site-packages/satellite_tle/fetch_tle.py", line 88, in fetch_tles_from_url
    if (lines[i + 1][0] == "1") & (lines[i + 2][0] == "2"):
IndexError: string index out of range
I tried this: pip install --upgrade satellitetle , but it didn’t seem to change the results.
From 7d829f9c 06 Dec, 2019 commit :
  • Force use of python3 instead of system default python version (goes wrong if default is python2)
For my station (Buster) with python2 and python3 installed :
cd satnogs-auto-scheduler
git pull
pip3 install ephem
pip3 install satellitetle
pip3 install requests
pip3 install lxml
pip3 install tqdm
pip3 install python-decouple
after that, this ok
I believe this has fixed my issues. I was able to manually run the command and the scheduling worked. The true test will be tonight at 00:00z, but generally I think I am back on track! Thank you everbody!
Ran pip uninstall for both of those, with and without sudo, nothing was there to uninstall.
Also, Ansible doesn’t show any errors or failed. I do see a couple of warnings. Here’s the output:
pi@satnogs1:~ $ sudo satnogs-setup
Applying configuration...
[WARNING]: Could not match supplied host pattern, ignoring: satnogs-setups
PLAY [satnogs-setups] *******************************************************************************************************************************************************************************************************************************************
skipping: no hosts matched
PLAY [satnogs_setups] *******************************************************************************************************************************************************************************************************************************************
TASK [Gathering Facts] ******************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [satnogs-setup : Configure satnogs-setup] ******************************************************************************************************************************************************************************************************************
ok: [localhost]
[WARNING]: Could not match supplied host pattern, ignoring: satnogs-clients
PLAY [satnogs-clients] ******************************************************************************************************************************************************************************************************************************************
PLAY [satnogs_clients] ******************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [satnogs-client : Install satnogs-client configuration] ****************************************************************************************************************************************************************************************************
ok: [localhost]
[WARNING]: Could not match supplied host pattern, ignoring: satnogs-radios
PLAY [satnogs-radios] *******************************************************************************************************************************************************************************************************************************************
PLAY [satnogs_radios] *******************************************************************************************************************************************************************************************************************************************
ok: [localhost]
[WARNING]: Could not match supplied host pattern, ignoring: hamlib-utils
PLAY [hamlib-utils] *********************************************************************************************************************************************************************************************************************************************
PLAY [hamlib_utils] *********************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [hamlib-utils : Install hamlib utilities configuration] ****************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [hamlib-utils : Start/stop rigctld service] ****************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [hamlib-utils : Start/stop rotctld service] ****************************************************************************************************************************************************************************************************************
ok: [localhost]
PLAY [snmpds] ***************************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [snmpd : Setup snmpd listen configuration] *****************************************************************************************************************************************************************************************************************
skipping: [localhost]
TASK [snmpd : Setup snmpd rocommunity configuration] ************************************************************************************************************************************************************************************************************
TASK [snmpd : Start/stop snmpd service] *************************************************************************************************************************************************************************************************************************
ok: [localhost]
PLAY [gpsds] ****************************************************************************************************************************************************************************************************************************************************
ok: [localhost]
TASK [gpsd : Start/stop gpsd service] ***************************************************************************************************************************************************************************************************************************
ok: [localhost]
PLAY RECAP ******************************************************************************************************************************************************************************************************************************************************
localhost                  : ok=13   changed=0    unreachable=0    failed=0    skipped=2    rescued=0    ignored=0
Press enter to continue...
did the stub for rtlsdr also change? did two passes with a new and old long running client on pi. Since the update there is no reception anymore (did not change params).
According the logs the qrg did not lock and the campaign failed :frowning:
pi@oe8rke-satnogs:~ $ journalctl -f -u satnogs-client.service
– Logs begin at Thu 2016-11-03 17:16:43 UTC. –
Dec 21 17:42:30 oe8rke-satnogs satnogs-client[374]: linux; GNU C++ version 6.2.0 20161010; Boost_106100; UHD_003.009.005-0-unknown
Dec 21 18:23:54 oe8rke-satnogs satnogs-client[374]: linux; GNU C++ version 6.2.0 20161010; Boost_106100; UHD_003.009.005-0-unknown
Dec 21 18:23:58 oe8rke-satnogs satnogs-client[374]: gr-osmosdr 0.1.4 (0.1.4) gnu radio 3.7.10
Dec 21 18:23:58 oe8rke-satnogs satnogs-client[374]: built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy soapy redpitaya
Dec 21 18:23:58 oe8rke-satnogs satnogs-client[374]: Using device #0 Realtek RTL2 838UHIDIR SN: 00000001
Dec 21 18:23:58 oe8rke-satnogs satnogs-client[374]: Using 32 buffers of size 163 84.
Dec 21 18:23:58 oe8rke-satnogs satnogs-client[374]: Found Rafael Micro R820T tun er
Dec 21 18:23:58 oe8rke-satnogs satnogs-client[374]: [R82XX] PLL not locked!
Dec 21 18:23:58 oe8rke-satnogs satnogs-client[374]: Exact sample rate is: 100000 0.026491 Hz
Any clue how to fix this or how to revert back? Target qrg was 437200000
br Robert
