Hello,
I am following this intruction for installation of satnogs: Ubuntu - Client Installation - SatNOGS Wiki
I removed gnuradio that previously installed but, I am keep getting GrSwig not found error:
~/gr-satnogs/build
% cmake …
– The CXX compiler identification is GNU 9.4.0
– The C compiler identification is GNU 9.4.0
– Check for working CXX compiler: /bin/c++
– Check for working CXX compiler: /bin/c++ – works
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Detecting CXX compile features
– Detecting CXX compile features - done
– Check for working C compiler: /bin/cc
– Check for working C compiler: /bin/cc – works
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Detecting C compile features
– Detecting C compile features - done
– Build type not specified: defaulting to release.
– Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython3.8.so (found suitable version “3.8.10”, minimum required is “3”)
– Looking for pthread.h
– Looking for pthread.h - found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
– Looking for pthread_create in pthreads
– Looking for pthread_create in pthreads - not found
– Looking for pthread_create in pthread - found
– Found Threads: TRUE
– Found PkgConfig: /bin/pkg-config (found version “0.29.1”)
– Checking for module ‘gmp’
– Found gmp, version 6.2.0
– Found GMP: /usr/lib/x86_64-linux-gnu/libgmpxx.so
– Using GMP.
– Found MPLIB: /usr/lib/x86_64-linux-gnu/libgmpxx.so
– Found Boost: /lib/x86_64-linux-gnu/cmake/Boost-1.71.0/BoostConfig.cmake (found suitable version “1.71.0”, minimum required is “1.71.0”) found components: date_time program_options system regex thread unit_test_framework
– Found Volk: Volk::volk
– User set python executable /usr/bin/python3
– Found PythonInterp: /usr/bin/python3 (found version “3.8.10”)
– Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython3.8.so (found suitable exact version “3.8.10”)
– Found Git: /bin/git
– Extracting version information from git describe…
– Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
– Found SWIG: /bin/swig4.0 (found version “4.0.1”)
– Looking for vorbis_bitrate_addblock in vorbis
– Looking for vorbis_bitrate_addblock in vorbis - found
– Found OggVorbis: /usr/lib/x86_64-linux-gnu/libogg.so;/usr/lib/x86_64-linux-gnu/libvorbis.so;/usr/lib/x86_64-linux-gnu/libvorbisfile.so;/usr/lib/x86_64-linux-gnu/libvorbisenc.so
– Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version “1.2.11”)
– Found PNG: /usr/lib/x86_64-linux-gnu/libpng.so (found version “1.6.37”)
– Found png++: /usr/include
– Found nlohmann_json: /lib/cmake/nlohmann_json/nlohmann_jsonConfig.cmake (found suitable version “3.7.3”, minimum required is “3.5.0”)
– Checking for module ‘itpp’
– Found itpp, version 4.3.1
– Found ITPP: /usr/lib/x86_64-linux-gnu/libitpp.so
– The ASM compiler identification is GNU
– Found assembler: /bin/cc
– Looking for getopt.h
– Looking for getopt.h - found
– Looking for stdio.h
– Looking for stdio.h - found
– Looking for stdlib.h
– Looking for stdlib.h - found
– Looking for memory.h
– Looking for memory.h - found
– Looking for string.h
– Looking for string.h - found
– Looking for getopt_long
– Looking for getopt_long - found
– Looking for memset
– Looking for memset - found
– Looking for memmove
– Looking for memmove - found
– Using install prefix: /usr/local
– Building for version: v2.3.5.0-1-g756d6f5a / 2.3.5git
– Found PythonLibs: /usr/lib/x86_64-linux-gnu/libpython3.8.so (found version “3.8.10”)
CMake Error at swig/CMakeLists.txt:36 (include):
include could not find load file:
GrSwig
CMake Error at swig/CMakeLists.txt:84 (GR_SWIG_MAKE):
Unknown CMake command “GR_SWIG_MAKE”.
– Configuring incomplete, errors occurred!
What could be the issue here I have?
I tried installing GrSwig individually, but not working.
