After obviousely sucesssful installation and station is online, I cannot get around thie issue during start of observation. It seems the limeSDR is not recognized.
Any suggestions are appreciated.
73, Stefan
SATNOGS_STATION_ID=2694
SATNOGS_SOAPY_RX_DEVICE=“driver=lime”
SATNOGS_RX_SAMP_RATE=2048000
SATNOGS_ANTENNA=LNAL
SATNOGS_STATION_LAT=47.02
SATNOGS_STATION_LON=15.263
SATNOGS_STATION_ELEV=410
The settings are basically the same as in 1.9.3
Aug 25 19:06:41 raspberrypi satnogs-client[1233]: rot_set_position: south_zero=0
Aug 25 19:06:41 raspberrypi satnogs-client[1233]: rot_set_position: range problem az=239.34(min=-180.00,max=180.00), el=0.457144(min=0.00,max=90.000000)
Aug 25 19:06:41 raspberrypi satnogs-client[1233]: rig_init: rig does not have rx_range!!
Aug 25 19:06:41 raspberrypi satnogs-client[1233]: network_open: hoststr=127.0.0.1, portstr=4532
Aug 25 19:06:41 raspberrypi satnogs-client[1233]: connect to 127.0.0.1:4532 failed, (trying next interface): Network error 111: Connection refused
Aug 25 19:06:41 raspberrypi satnogs-client[1233]: network_open: failed to connect to 127.0.0.1:4532
Aug 25 19:06:41 raspberrypi satnogs-client[1233]: rig_get_vfo: no rig and/or vfo? rig=0x7f8c000c40, vfo=0x7f97ffd36c
