ISS SSTV Event - from 2026-05-08 to 2026-05-12
"ARISS fans, we are GO for SSTV Series 32!
Transmissions will kick off on Friday May 8 around 10:30 UTC | 6:30 AM ET.
With the ARISS-USA.org domain currently off-line, we ask you hold your decodes and we’ll announce when you can upload your images for certificates."
Post made by ARISS on Twitter/X. See HERE (Nitter HERE)
Good luck to everyone :grin: !!
Screenshot from 2026-05-06 22-07-32
84 degree (max elevation). That’s a good start!
Thank you.
2026-05-08 20:30
2026-05-08 20:33
2026-05-08 23:47
2026-05-09 01:25
2026-05-09 10:09 UTC over :indonesia:
2026-05-09 10:12 UTC over :indonesia:
ISS over north Myanmar (and a building in the way…)
A much better ISS image received in north Myanmar at about 13 degrees elevation, local time of reception was 4.00am, (and I only got out of bed so that my school students can benefit from the certificate!)
over :indonesia: 2026-05-09 21:51 UTC
2026-05-09 19:44
over :indonesia:
2026-05-10 09:20 UTC
2026-05-10 09:23 UTC
On May 9 every year, Russia celebrates Victory Day
9 мая (pronounced “devyat maya”)
This is the standard way to write “May 9” in Russian
huray i got total 3 good sstv. minimum to got diploma from iss
dont forget to submit here
the fastest result in my life, submit, and wait around 5 minutes, refresh your inbox:
thank you RUSSIA TEAM!
Also, don’t forget THIS certificate !!
double degree , 2 diploma in one home work. from russia, and from mexico.
2026-05-11 08:34 UTC over :indonesia:
