ISS SSTV - ARISS "Amateur radio on Shuttle, Mir and ISS" SSTV event - June 21-27
from ARISS-SSTV images: ARISS "Amateur radio on Shuttle, Mir and ISS" SSTV event - June 21-26
The ARISS team will be transmitting SSTV images continuously from June 21 until June 26. The images will be related to some of the amateur radio activities that have occurred on the Space Shuttle, Mir space station and the International Space Station.
The schedule start and stop times are:
Monday, June 21 – Setup is scheduled to begin at 09:40 UTC (transmissions should start a little later).
Saturday, June 26 – Transmissions are scheduled to end by 18:30 UTC.
Downlink frequency will be 145.800 MHz and the mode should be PD120.
Those that recently missed the opportunity during the limited period of MAI transmissions should have numerous chances over the 6 day period to capture many (if not all 12) of the images.
UPDATE - June 19
The addition of a EVA by the US crew on June 25 will change the dates of operation related to this activity. The exact schedule has not yet been updated but no ham radio activity can occur during the EVA period.
SSTV transmitter has been enabled for scheduling on Network.
Several observations have been scheduled in Network, due to the duration of the event, I’ve scheduled only passes over 45 degrees, feel free to add observation bellow that elevation.
Observations scheduled until 2021-06-25 00:30 for passes that are over 45 degrees.
There is also an update in https://ariss-sstv.blogspot.com/2021/06/ariss-amateur-radio-on-shuttle-mir-and.html:
UPDATE - June 22
SSTV will be OFF June 25 from ~06:35 until ~19:35 UTC to support the U.S. EVA.
Observations scheduled until 2021-06-26 22:00 for passes that are over 45 degrees.
UPDATE - June 23
Looks like we have some changes to the operational dates. ARISS SSTV will get another day to make up for off period. Transmissions should run until June 27 ~18:30 UTC after coming back on post EVA.
