fredy
June 27, 2021, 7:00pm
1
Three satellites are going to deployed from Cygnus:
DhabiSat (former MYSat-2)
IT-SPINS
Gunsmoke-J
The first two has been added in DB:
Dhabisat with temporary NORAD ID: 99670
IT-SPINS with temporary NORAD ID: 99690
No info about Gunsmoke-J, unknown on which frequency it transmits.
Datetime comes from Implement DhabiSat decoder struct (#57) · Issues · librespacefoundation / SatNOGS / satnogs-decoders · GitLab
Satellites that will be in this deployment from this twitter thread:
fredy
June 29, 2021, 7:22pm
2
Using TLE set from Add DhabiSat to SATNOGS DB (#182) · Issues · librespacefoundation / SatNOGS Operations · GitLab for both DhabiSat and IT-SPINS, everything is ready for the deployment with several observations scheduled.
fredy
June 30, 2021, 1:49am
3
Both DhabiSat and IT-SPINS are alive!
fredy
July 1, 2021, 8:47am
4
@pierros with @cgbsat strf tools has generated TLE sets for the satellites:
Dhabisat
1 99670U 21181.00000000 .00000000 00000-0 00000-0 0 07
2 99670 51.6425 279.3860 0000001 270.8661 138.2210 15.22630713 09
IT-SPINS
1 99690U 21181.00000000 .00000000 00000-0 00000-0 0 09
2 99690 51.6425 279.3860 0000001 270.8661 138.2210 15.22630713 01
EDIT: FIXED the checksum on IT-SPINS TLE set
K4KDR
July 1, 2021, 9:13am
5
Many thanks for the updated info!
Please note that the second line for IT-SPINS has an incorrect checksum; if you wish to import this entry into GPredict (or any other tool that requires a correct checksum), use:
IT-SPINS
fredy
July 1, 2021, 9:23am
6
Thanks! There was a copy paste error there…I’ve just fixed it in the initial post.
fredy
July 6, 2021, 8:57am
7
New TLE sets:
DhabiSat
1 99670U 21185.20000000 .00000000 00000-0 00000-0 0 03
2 99670 51.6425 259.4174 0000001 102.0451 307.7489 15.22672982 04
IT-SPINS
1 99690U 21185.20000000 .00000000 00000-0 00000-0 0 05
2 99690 51.6425 259.4174 0000001 102.0451 307.7489 15.22672982 06
fredy
July 7, 2021, 6:08pm
8
We have 5 TBA(To Be Assigned) TLE sets (49013-49017) from space-track.org that describe deployments from ISS.
By running ikhnos, it looks like that DhabiSat is OBJECT ST(49016) and IT-SPINS is OBJECT SU(49017). However let’s wait for the final assignment before identifying.
fredy
July 7, 2021, 6:18pm
9
Please keep also in mind that ID of the above IDs may change in the next iterations.
fredy
July 9, 2021, 6:32am
10
TLE sets have been fixed and assigned, so for the two satellites we have:
DhabiSat(MySat-2) is OBJECT F(49016) , , more details can be found in ikhnos-identification-49016
IT-SPINS is OBJECT G(49017) , , more details can be found in ikhnos-identification-49017
