fredy
June 21, 2021, 8:33am
1
MIR-SAT1 will be deployed at 2021-06-22T10:55UTC
more info in https://spacemauritius.com/
The satellite has been added in SatNOGS DB and scheduled in several stations in SatNOGS Network.
Also there are some awards for stations that will receive MIR-SAT1, more info in MIR-SAT1 Special Award | Mauritius Amateur Radio Society
fredy
June 22, 2021, 12:28pm
2
MIR-SAT1 is alive:
first signal in Network on @vk2byf ’s station SatNOGS Network - Observation 4298920 from a very low pass.
first demodulated data on 853 - NewUlm-UHF-2 station SatNOGS Network - Observation 4304472
fredy
June 23, 2021, 9:42am
3
To Station Owners, if you are interested, check this MIR-SAT1 awards announcement:
fredy
June 23, 2021, 8:47pm
4
A TLE set for MIR-SAT1 generate by @pierros using strf tools .
MIR-SAT1
1 99718U 21174.56000000 .00000000 00000-0 00000-0 0 03
2 99718 51.6428 311.1970 0002856 103.6299 26.7813 15.50352971 00
fredy
June 24, 2021, 7:37am
5
More accurate TLE set for MIR-SAT1, generated by @pierros using @cgbsat ’s strf tools .
MIR-SAT 1
1 99718U 21175.00000000 .00000000 00000-0 27196-4 0 02
2 99718 51.6438 309.0277 0003330 123.4770 302.3095 15.48972405 01
fredy
June 28, 2021, 7:20am
6
New TLE set for MIR-SAT1, generated by @pierros using @cgbsat ’s strf tools :
MIR-SAT 1
1 99718U 21179.00000000 .00000000 00000-0 27196-4 0 06
2 99718 51.6438 289.2346 0003276 135.1233 298.7709 15.49579413 03
EU1SAT
June 28, 2021, 11:54pm
7
www.space-track.org published TLE:
1 48867U 98067SN 21179.30801523 .00007576 00000-0 14112-3 0 9992
2 48867 51.6444 287.6789 0002965 206.9147 153.1689 15.49891167 944
1 48868U 98067SP 21179.69602259 .00013025 00000-0 23878-3 0 9995
2 48868 51.6439 285.7711 0003006 182.6608 177.4342 15.49640979 1031
fredy
June 29, 2021, 12:18am
8
Thanks @EU1SAT from those two sets it looks like that the OBJECT SP(48868) fits better. As the TLE set are still in TBA(To Be Assigned) status, we should wait for identification. For now we just follow OBJECT SP in DB and Network for MIR-SAT1.
The other object looks like that was from the same deployment… but I have no idea which satellite it is.
EDIT: Two CubeSats successfully deployed from "Kibo"! | JAXA Human Spaceflight Technology Directorate it confirms the two satellites with one being a “business” one but no more info which one.
K4KDR
June 29, 2021, 4:09pm
9
Unattended MIR-Sat1 decodes here overnight (29-June) included “digipeater_enable = True / pacsat_broadcast_enable = True / pacsat_broadcast_in_progress = True”.
Tried 9k6 digi uplink on 85° pass just ended (1500utc 29-June) w/ no luck. Can anyone confirm if ‘CQ via 3B8MIR-1’ is the digi address? Thanks!
EU1SAT:
48867
As we can see in the attached images object 48868 is without a doubt MIR-SAT1
fredy
June 30, 2021, 1:36pm
11
Let’s wait for the TLE sets to be assigned from space-track.org side, so we can also identify it in DB and Network.
fredy
July 3, 2021, 4:56pm
12
Now that TLE sets are assigned we have identified that MIR-SAT1 is OBJECT 98067SP(48868) , more details can be found in ikhnos-identification-48868 .
By the way, the mystery “business” satellite is G-SATELLITE 2(BD-28).
Unfortunately space-track.org has mis-identified the two objects in their catalog.
