KITSUNE is the first W6U CubeSat deployment for J-SSOD. It is developed by the first-time collaboration with HAK Consortium. Together with KITSUNE the satellite IHI-SAT will also be released.
KITSUNE has been added in DB with the temporary NORAD ID 99415. It will be available for scheduling in Network a couple of hours before its deployment.
While the 437.375 MHz downlink has been very weak (to the point that you wonder if there is an antenna deployment issue), the 400.960 CW beacon is VERY strong.
I noticed on the pass just ended (2115utc 25-Mar) that there was already a large deviation from the doppler based on the ISS orbit.
Have any possible objects been identified yet that are candidates for KITSUNE?
Very sorry for the accidental SatNogs data upload to #99415 - that was NOT a 4k8 packet from KITSUNE. However, w/ the improved TLE, I did notice that the computer tracking the 437.375 downlink (with a directional antenna) had the strongest CW signal that I’ve seen so far on that frequency!
So, hopefully the spacecraft is healthy on that downlink as well.
