Connect with our Maya-5 and Maya-6 cube satellites starting tomorrow. Here’s how:
Track the Maya-5 (DX5MYA) and Maya-6 (DX6MYA) CubeSats and listen to their Morse-coded CW beacon at 437.375 MHz which will be transmitted by the satellites 30 minutes after release.
The two-line elements (TLE) of the satellites will be available only after deployment, so initially the TLE of ISS (NORAD ID 49274) may be used.
With the received CW beacon, know its status using the Birds-4 CW Decoder software that you can download through: BIRDS4 CW decoder - Google Drive.
All amateur radio community members are encouraged to participate in tracking #Maya5 and #Maya6! As a humble token of appreciation, we will send you a QSL card in return.
We have some CW reception, it is not clear if they are coming from Maya-5 or Maya-6 or both. From an attempt to decode the CW I get something like TRASHMAYA.
I’ve assigned to follow 57419 for Maya-5 and 57420 for Maya-6, but we will need some time for the TLE to be assigned and for the satellites being separated in order to identify them.
Based on this observation SatNOGS Network - Observation 7917767 which should be tracking Maya-5 it seems we should flip the tracked TLE between Maya-6 and Maya-5.
Since Maya-6’s CW appears to be straight / tracked for doppler properly in the observation, and Maya-5’s CW appears to have doppler.
Thanks for the analysis, I’ve swapped the NORAD IDs we follow for each object. Let’s get a couple more observations to verify it and then let’s identify them.
For some reason it seems that space-track.org has identified 57419 as Maya-5, probably seems to be a mis-identification.
