It will be available for scheduling in Network after adding TLE one day before the deplyment (2020-04-27). The scheduling will be tracked by this issue, general updates about it will be posted here.
@W7KKE station was the first one confirming reception of Quetzal-1 in network and also decoding some frames too. More observations follow, the satellite seems to transmit loud and clear. Still we use ISS TLE for following the objects. The first observation https://network.satnogs.org/observations/2111021/.
Thanks to all the station owners for helping with this deployment!
As we don’t have any TLE from spacetrack yet, @cgbsat have done some calculations using strf and calculated some better TLEs that have been updated in Network:
Spacetrack has published two TLE sets related with objects deployed from ISS, OBJECT RK (45597) and OBJECT RL (45598). By running ikhnos, OBJECT RL(45598) fits perfect the waterfalls of observations, bellow are two different observations and how they compare with the two objects:
From the above, and with the expectation that at most 2 satellites would be deployed (the other one is probably the expected but not announced to be deployed G-SATELLITE), we have identified Quetzal-1 as OBJECT RL (45598).
