When setup start or end time, the system appear “Internal Server Error”.
Can anyone explain and fix?
@BV2DQ Does this happen in observations/new page?
Does this happen every time?
If yes please write here the steps you follow with the values you use for the start/end and the other field. This will help us to reproduce and find out what is the issue.
