Installing Satnogs in Raspberry Pi OS 64 bits
Hello,
the upcoming 64-bit Raspberry Pi OS can be installed on Raspberry Pi 3 and Raspberry Pi 4 models. You can download an early beta image right now from here. Below is my recipe for installing Satnogs:
# configure your raspi as you like
sudo raspi-config
# ssh is handy to have
sudo systemctl enable ssh
# reboot and login again
# ansible
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 93C4A3FD7BB9C367
echo "deb http://ppa.launchpad.net/ansible/ansible/ubuntu trusty main" > ansible.list
sudo mv ansible.list /etc/apt/sources.list.d/
sudo apt update
sudo apt install ansible
# download everything satnogs with ansible
git clone https://gitlab.com/librespacefoundation/satnogs/satnogs-client-ansible
cd satnogs-client-ansible/
cp -r production.dist/ production
nano production/inventory/hosts # really needed ?
nano production/inventory/host_vars/satnogs/main.yml # really needed ?
# we are working in the raspberry, so use local.yml
sudo ansible-playbook -i production/inventory -K local.yml
# if problems with the dependencies, like satnogs-flowgraphs downgrade,
# copy the apt command and install the recommended version of satnogs-flowgraphs manually
# and launch again the ansible playbook command
# configure the station
sudo satnogs-setup
# run again raspi-config if you do not want the X-Windows session started
That should get your Satnogs system installed and configured. It would be interesting to measure if there are performance wins for running the satnogs flowgraphs in a 64 bits OS.
Hmmm… How do the 32 packages work on an arm64 OS? We do have aarch64 repositories but I don’t see them added in your recipe.
There is a satnogs.list in /etc/apt/sources.list.d/:
http://download.opensuse.org/repositories/home:/librespace:/satnogs/Debian_10
I think that file is installed from a task defined in the ansible recipe roles/common/tasks/apt.yml.
