Hi everybody,
I try to set-up a second station, using an old laptop - Toshiba Satellite L300.
I installed Debian 11 Bullseye, it seems is working fine.
I used PE0SAT instructions ( see Debian | Amateur Radio – PEØSAT ).
Exempting 1 step, where I am not sure I was doing right, it seems the installation was succesfully.
After that, I tried to install SatMonitor, but it was a failure.
Now, if I try to modify the setup, It doesnt work.
So, this is the Support report
“versions”: {
“satnogs-client”: “1.8.1”,
“satnogs-flowgraphs”: “1.5-1”,
“gr-satnogs”: “2.3.5.0-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14”,
“satnogs-config”: “0.13.2”
“state”: {
“is-applied”: false,
“pending-tags”: null
“system”: {
“date”: “2024-05-31T12:54:17.264366+00:00”,
“distribution”: {
“DESCRIPTION”: “Debian GNU/Linux 11 (bullseye)”,
“RELEASE”: “11”,
“CODENAME”: “bullseye”,
“ID”: “Debian”
“pending-updates”: false,
“platform”: {
“system”: “Linux”,
“node”: “yo4dft”,
“release”: “5.10.0-28-amd64”,
“version”: “#1 SMP Debian 5.10.209-2 (2024-01-31)”,
“machine”: “x86_64”
“memory”: {
“total”: 2984103936,
“available”: 1387610112,
“percent”: 53.5,
“used”: 1277399040,
“free”: 259981312,
“active”: 386379776,
“inactive”: 2030755840,
“buffers”: 53145600,
“cached”: 1393577984,
“shared”: 153530368,
“slab”: 105574400
“disk”: {
“total”: 238530957312,
“used”: 13652316160,
“free”: 212687331328,
“percent”: 6.0
“configuration”: {
“satnogs_antenna”: “RX”,
“satnogs_ppm_error”: “30”,
“satnogs_radio_flowgraphs_version”: “1.5-1”,
“satnogs_rf_gain”: “40.2”,
“satnogs_station_elev”: “50”,
“satnogs_station_id”: “3600”,
“satnogs_station_lat”: “44.141”,
“satnogs_station_lon”: “28.617”
and when I try to modify the setup, if I use Update configuration tool
tarting Ansible Pull at 2024-05-31 16:09:48
/usr/bin/ansible-pull -d /root/.satnogs/ansible -U librespacefoundation / SatNOGS / satnogs-ansible · GitLab -o -t satnogs-setup local.yml -C stable
/usr/lib/python3/dist-packages/paramiko/transport.py:219: CryptographyDeprecationWarning: Blowfish has been deprecated and will be removed in a future release
“class”: algorithms.Blowfish,
[WARNING]: Could not match supplied host pattern, ignoring: yo4dft
localhost | SUCCESS => {
“after”: “e6b68d6755a085f79c6c4697d75b055d3699b36a”,
“before”: “e6b68d6755a085f79c6c4697d75b055d3699b36a”,
“changed”: false,
“remote_url_changed”: false
Repository has not changed, quitting.
when I try to use Apply,
Executing playbook local.yml
localhost on hosts: localhost -
Gathering Facts…
Check Ansible version…
Check distribution…
Remove APT configuration disabling recommends…
Update APT cache…
Retrying… (1 of 4)
Retrying… (2 of 4)
Retrying… (3 of 4)
localhost failed | msg: Failed to update apt cache: E:The repository ‘Index of /gpredict-team/ppa/ubuntu oracular Release’ does not have a Release file., W:Updating from such a repository can’t be done securely, and is therefore disabled by default., W:See apt-secure(8) manpage for repository creation and user configuration details., W:http://ppa.launchpad.net/ansible/ansible/ubuntu/dists/focal/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ansible.gpg are ignored as the file is not readable by user ‘_apt’ executing apt-key., W:http://download.opensuse.org/repositories/home:/librespace:/satnogs/Debian_11/./InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ansible.gpg are ignored as the file is not readable by user ‘_apt’ executing apt-key. -
Play recap -
localhost : ok=4 changed=0 unreachable=0 failed=1 rescued=0 ignored=0
cristian@yo4dft:~$
If apt update
cristian@yo4dft:~$ sudo apt update
[sudo] parolă pentru cristian:
Ignorat:1 Index of /gpredict-team/ppa/ubuntu oracular InRelease
Luat:2 /repositories/home:/librespace:/satnogs/Debian_11 - openSUSE Download ./ InRelease [1.551 B]
Atins:3 Index of /ansible/ansible/ubuntu focal InRelease
Eroare:4 Index of /gpredict-team/ppa/ubuntu oracular Release
404 Not Found [IP: 185.125.190.80 80]
Citire liste de pachete… Terminat
E: The repository ‘Index of /gpredict-team/ppa/ubuntu oracular Release’ does not have a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: http://download.opensuse.org/repositories/home:/librespace:/satnogs/Debian_11/./InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ansible.gpg are ignored as the file is not readable by user ‘_apt’ executing apt-key.
W: http://ppa.launchpad.net/ansible/ansible/ubuntu/dists/focal/InRelease: The key(s) in the keyring /etc/apt/trusted.gpg.d/ansible.gpg are ignored as the file is not readable by user ‘_apt’ executing apt-key.
cristian@yo4dft:~$
When apt upgrade
cristian@yo4dft:~$ sudo apt upgrade
Se construiește arborele de dependență… Terminat
Se citesc informațiile de stare… Terminat
Calculez înnoirea… Terminat
0 înnoite, 0 nou instalate, 0 de șters și 0 neînnoite.
Any solutions, exempting re-installing ?
Thank you in advance,
Cristian
cristian@yo4dft:~$ sudo systemctl status satnogs-client
● satnogs-client.service - SatNOGS client
Loaded: loaded (/etc/systemd/system/satnogs-client.service; enabled; vendo>
Active: active (running) since Sat 2024-05-25 14:09:53 EEST; 1h 57min ago
Main PID: 429 (satnogs-client)
Tasks: 5 (limit: 3353)
Memory: 63.8M
CPU: 8.484s
└─429 /var/lib/satnogs/bin/python /var/lib/satnogs/bin/satnogs-cli>
mai 25 15:57:45 yo4dft satnogs-client[429]: satnogsclient.scheduler.tasks - ERR>Client Error: Unauthorized for url: https://network.satnogs.org/api/jobs/?ground_station=9999&lat=37.971&lon=23.725&alt=1
