I want use SDRplay 1A as RX device
Step 1.
did install API driver
./SDRplay_RSP_API-Linux-3.15.2.run
lsusb:
Bus 001 Device 004: ID 1df7:3000 SDRplay RSP1A
Step 2.
sudo apt-get install build-essential cmake libsoapysdr-dev
git clone GitHub - pothosware/SoapySDRPlay3: Soapy SDR plugin for SDRPlay APIv3
cd SoapySDRPlay
mkdir build
cd build
cmake …
make
sudo make install
all 1. and 2. steps worked without error
but
SoapySDRUtil --probe=“driver=sdrplay”
Probe device driver=sdrplay
[ERROR] SoapySDR::loadModule(/usr/local/lib/SoapySDR/modules0.7/libsdrPlaySupport.so)
dlopen() failed: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.34’ not found (required by /usr/local/lib/libsdrplay_api.so.3)
Error probing device: SoapySDR::Device::make() no match
any help are welcome
