InnoCube Anniversary CW Beacon
Luki, i just started following Innocube, so i understand.
This is a regular morse signal from Innocube, copy it as you would any morse signal. You can HEAR it on FM, but its not easy to copy. :confused:
I use an FT818 in cw mode, and manually spin the tune dial for doppler shift. I also record the audio, because my morse skills are terrible, and i have to replay it a million times.
I assume youre familiar with satellites, doppler, and gear to find-and-hear them… followup with any questions you have… the folks here are awesome.
you can start with the easiest way with zero tools . just need internet , browser and audio software. right.
open https://network.satnogs.org
click Observations > Browse
click this button
view on waterfall of each obs, and choose when you look a sign of morse signal like this:
for example this obs
go to bottom page, and click on download audio
install audio software. i recomend sonic-visualiser , because its free open source and available for all platform.
on linux install:
sudo apt update
sudo apt install sonic-visualiser
file > open > select the satnogs ogg audio file
and just follow what i did in this screen capture
you can see the dot and dash. that is the morse code from satellite.
73
dont know why the video can’t be played. you can see in this direct link
Audacity also can visually represent audio tracks so dots and dashes are seen distinctly. Example - christmas beacon from INNOCUBE. And then use any online translator (text ones are more reliable) or try it do it yourself with Morse code tables)
My guide post from last year’s April showing how to visualize CW beacons from recordings in SSB using ocenaudio and linking to upload forms for 11 CW beaconing satellites for playing with.
thx bali
Hello vici,
My name is nishikazu0417 (Kazuki.N, JF6FYI), an amateur radio operator from Japan.
I think this is a wonderful event celebrating the first anniversary of InnoCube’s launch. Thank you very much for organizing it.
If possible, I would like to kindly request CW beacon transmissions during the following two passes over Japan (UTC), for Japanese amateur radio enthusiasts.
  • January 14, 2026 (UTC)
    Maximum elevation: 26°
    AOS: 01:43:57
    LOS: 01:54:39
    Preferred start time for transmission: 01:47:00
    Maximum elevation: 64°
    AOS: 13:50:21
    LOS: 14:01:45
    Preferred start time for transmission: 13:54:40
The second pass is especially favorable for my location (Grid locator: PM53kv).
Thank you very much for your consideration.
Best regards,
Kazuki Nishioka JF6FYI
The pass over 38.3170, -81.7168 (38.317N, 81.7168W) from 11:04:34 to 11:15:48Z if that can be scheduled is our best for 1/14 - will be observing beacon or not.
Happy 1st Birthday in orbit once again! :tada::rocket: Hope the satellite is doing great!
I would like to request a CW beacon transmission during one of these two time windows on January 14th (both ~10 minutes), whichever is more convenient for the team/satellite passes:
**11:17 – 11:27 UTC
12:51 – 13:01 UTC**
My location should have potential visibility in both periods, but please feel free to choose whichever fits best into the overall schedule.
Thank you so much for organizing this anniversary event — really looking forward to listening for the beacon!
I’m really happy that so many of you want to receive the beacon! The list of schedules is as follows:
Datetime (UTC)
14.01.2026 01:47
14.01.2026 01:59
14.01.2026 02:38
14.01.2026 02:52
14.01.2024 03:22:30
14.01.2026 03:32
14.01.2026 03:53
14.01.2026 04:14
14.01.2026 04:25
14.01.2026 04:55
14.01.2026 05:05
14.01.2026 06:36
14.01.2026 09:29
14.01.2026 09:39
14.01.2026 11:02
14.01.2026 11:10
14.01.2026 11:21
14.01.2026 12:55
14.01.2026 13:05
14.01.2026 13:47
14.01.2026 13:55
14.01.2026 14:38
14.01.2026 15:26
14.01.2026 15:54
14.01.2026 16:10
14.01.2026 16:59
14.01.2026 17:31
14.01.2026 18:44
14.01.2026 20:17
14.01.2026 21:52
14.01.2026 23:22
Thank you!
Good morning/evening!
The 0252 message came booming in at 13 deg! I love how clear and readable this signal is, even low in the sky.
Thanks for the event. I’ll be chasing the 1554 message also (That’s also when I get AOS, so it’ll be interesting to see if I can catch that first message right at the horizon! Anyone want to make a prediction?)
Happy hunting, y’all.
chris
VERY STRONG signal on this first pass over Brazil :brazil:
I received a total of 4 clear messages (I’ll post the results in a few minutes)
:pencil: Edit :
The signal can also be seen on my SatNOGS station #3538 (See HERE), however, as I am using a 4-element Yagi antenna pointed at the zenith on the SatNOGS station, the signal is very weak.
Happy birthday InnoCube :partying_face: !!!
Received the CW Beacon over VU Region at 5:05 UTC 17deg elevation
Thank you very much for transmitting the InnoCube birthday CW beacon!
During the transmission at 2026-01-14 01:47 (UTC), the beacon was successfully received by multiple SatNOGS ground stations across Japan. :japan:
Remarkably, traces of the signal were visible even at stations with antennas partially blocked by nearby buildings, and the beacon could also be decoded at stations operating in high-noise environments.
I am very much looking forward to tonight’s pass and the transmission starting around 13:55 (UTC).
Happy Birthday, InnoCube! :tada:
Below, I have attached a table summarizing the reception results from each station.
09:39 UTC - Strong signal in :greece:.
DP1NNO 0.06 DEG C HAPPY BIRTHDAY
DP1NNO 2.56 DEG C HAPPY BIRTHDAY
DP1NNO 3.88 DEG C HAPPY BIRTHDAY
DP1NNO 4.84 DE
Thanks for this broadcast. Happy birthday!
11:02 UTC - Very strong signal in :greece: at < 5 deg elevation with obstacles! I missed only the 1st tx at AOS.
… 3.19 DEG C … 4.44 DEG C … 5.31 DE
using KENWOOD D75, I received a strong CW signal, which is as follows
Fascinating to see such a huge interest in receiving CW beacons.
I wonder why almost none of the people here ever uploaded a received CW beacon from the other satellites.
I caught the 1554 message about 10 seconds before my app said I’d get AOS… What a beautiful signal at 0.0 degrees (or less)! Only done that with the ISS previously!
Fun!
