Newbie here…
I believe I have everything setup and registered correctly for ground station 103. However, my initial scheduled test yielded no data being sent. I’m in the dev site.
Are there lower level tests that can be performed on the RPI to establish that in fact the RTL SDR and Rotor controller are actually working correctly?
Why doesn’t the “Schedule” button work for me on the Upcoming passes page for my ground station?
I’ll note my configs look fine in: /etc/supervisord.d
I do see a socket error in the satnogs-error.log…
2017-06-06 00:25:09,382 - satnogsclient - INFO - Starting status listener thread…
2017-06-06 00:25:09,386 - satnogsclient - INFO - Dir /tmp/.satnogs/data/files/
2017-06-06 00:25:09,389 - satnogsclient - INFO - Check dir /tmp/.satnogs/data/files/SU_LOG
2017-06-06 00:25:09,390 - satnogsclient - INFO - Check dir /tmp/.satnogs/data/files/WOD_LOG
2017-06-06 00:25:09,392 - satnogsclient - INFO - Check dir /tmp/.satnogs/data/files/EXT_WOD_LOG
2017-06-06 00:25:09,404 - satnogsclient - INFO - Press Ctrl+C to exit SatNOGS poller
WebSocket transport not available. Install eventlet or gevent and gevent-websocket for improved performance.
File “/usr/bin/satnogs-client”, line 9, in
load_entry_point(‘satnogsclient==0.3’, ‘console_scripts’, ‘satnogs-client’)()
File “/usr/lib/python2.7/site-packages/satnogsclient/main.py”, line 22, in main
socketio.run(app, host=‘0.0.0.0’)
File “/usr/lib/python2.7/site-packages/flask_socketio/init.py”, line 469, in run
use_reloader=use_reloader, **kwargs)
File “/usr/lib/python2.7/site-packages/flask/app.py”, line 841, in run
run_simple(host, port, self, **options)
File “/usr/lib/python2.7/site-packages/werkzeug/serving.py”, line 736, in run_simple
inner()
File “/usr/lib/python2.7/site-packages/werkzeug/serving.py”, line 696, in inner
fd=fd)
File “/usr/lib/python2.7/site-packages/werkzeug/serving.py”, line 584, in make_server
passthrough_errors, ssl_context, fd=fd)
File “/usr/lib/python2.7/site-packages/werkzeug/serving.py”, line 501, in init
HTTPServer.init(self, (host, int(port)), handler)
File “/usr/lib/python2.7/SocketServer.py”, line 417, in init
self.server_bind()
File “/usr/lib/python2.7/BaseHTTPServer.py”, line 108, in server_bind
SocketServer.TCPServer.server_bind(self)
File “/usr/lib/python2.7/SocketServer.py”, line 431, in server_bind
self.socket.bind(self.server_address)
File “/usr/lib/python2.7/socket.py”, line 228, in meth
return getattr(self._sock,name)(*args)
socket.error: [Errno 98] Address already in use
[root@satnogs supervisor]#
