I have a USB dongle which looks exactly like this picture, however I do not know how to identify the chip inside.
The packaging looks like this, and (vexingly) contains no information whatsoever as to a model number or any other kind of identification of the device.
Can I identify it somehow? Is there a linux (preferably) application to interface to these things and get the info off it (and to just play with it a bit so I can see how it all works?)
@rspencer I don’t know if via sw there is a method to do what you want.
Maybe if you open the dongle case and take a picture of the chip we can try to identify it…
I’ll warn you. I have one of those. I’ve been picking up a lot of interference. On several sites they suggest the dongle with a usb cable to get it away from the pc. That and put a ferrite bead around the cable. Also good grounding, which is always a great idea. Some have even enclosed the dongle inside a grounded and shielded box. I haven’t had to chance to try any of these to see what really nails it. Probably all of it.
I hadn’t thought about it but using a laptop with just an ac adapter isn’t grounded at all. So I’ve got the usb extension cable. Now when I have time I can see how to get the best response. Just thought I’d share if you run into this too. That way you can be prepared if you need to make changes quick and at least have stuff on hand to fix it if it does.
