I need help, Im new
Hello. I can’t get anything to appear in data. if in the cascade, do you need to activate something?
@LW2DYB you are going to see data in observations’ data tab if your station has demodulated data and sent them to Network.
Here is one example from your station SatNOGS Network - Observation 5334015.
Demodulating signals depends on several factors, for example:
  1. If the satellite transmits or not
  2. If the received signal is strong enough to be above noise (good SNR)
  3. If the client has a demodulator for the satellite
If you schedule from the station page, you can filter the success rate of a satellite, this will allow you to observe satellites that transmitting. From there you can search and choose the ones that have observations with data (you can filter this in observations search).
Finally I would like to add that even observations without demodulated data are useful in Network, as in waterfall data you can check if the satellite was transmitting or not, or if the signal is drifted.
If you have any further questions, let us know.
so the demodulator is in my raspi, not in satnogs web. I only downloaded the satnogs image and configured it, I did not download any demodulator. I have to download one. ???
The demodulators come with the client image and they are updated automatically when you update your station.
