I don’t have a SATNOGS station, but I started sending in telemetry via gr-satellites and the DK3WN’s telemetry forwarder. How can I find what and how much telemetry I have sent in? On a specific satellite page there is only a mention of the last contributed telemetry sent in by whom. Thank you.
You can have a first look at the statistics of SatNOGS DB:
https://db.satnogs.org/stats
You will find your username suffixed by the locator calculated from provided longitude and latitude values.
The data itself can be found on the telemetry end-point of the specific satellite in its raw representation (hexlified, like 0xaa is represented as “AA”).
If you provide data for a satellite for which we have a dashboard, you can find that data represented as graph on our dashboards instance:
Thank you for the info and the links and it provides part of what I am looking for. The stats page is what I’m looking for, but it only gives me the total of what I have sent in. I am interested in more detailed stats, like what satellite, how many frames, when, etc. Are there more detailed stats?
Unfortunately there aren’t currently more detailed stats. I’ve just opened an issue about having more of them.
Please add a comment on the issue with a list of the stats that you would like to see.
