I have been chasing satellites for a long time.
Started with an $10 RTL-SDR chasing weather satellites.
I have all the hardware to make a VHF/UHF SDR based Receive only ground station but can’t seem to find a link on how to create a ground station and add it to the network.
I would appreciate if someone could steer me in the right direction.
I would start with an RTL-SDR maybe run it on one of my RPis, fed by one of my home-brew QFH antennas with masthead LNA4ALL preamps. It’s still my simplest and best RX antenna.
Currently I have my 2m/70cm yagies steered by an Arduino thanks to sarcnet.org, hamlib and Gpredict. Eventually I could add this setup to the network if there is a way to control it on-line.
Thanks for your help. I’m a SatNOGS newby.
Bob vk2byf
Hi @vk2byf,
Welcome to SatNOGS!
First you will need to log in the network, with the same credentials you joined here, and create a station there then follow the instructions in the wiki and especially in the article about raspberry pi and let us know if something is not clear.
Thanks fredy. I’ll give it a go and see what happens.
