Sorry I meant the logs for the satnogs-client service after you restart the satnogs-client:
journalctl -f -u satnogs-client.service
Looking for more error messages
in 06 20:50:32 raspberrypi satnogs-client[5258]: from satnogsclient import main
juin 06 20:50:32 raspberrypi satnogs-client[5258]: File â/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/init.pyâ, line 21, in
juin 06 20:50:32 raspberrypi satnogs-client[5258]: logging.basicConfig(format=settings.LOG_FORMAT, level=getattr(logging, settings.LOG_LEVEL))
juin 06 20:50:32 raspberrypi satnogs-client[5258]: AttributeError: module âloggingâ has no attribute 'DEBUG â
juin 06 20:50:32 raspberrypi systemd[1]: satnogs-client.service: Main process exited, code=exited, status=1/FAILURE
juin 06 20:50:32 raspberrypi systemd[1]: satnogs-client.service: Failed with result âexit-codeâ.
juin 06 20:50:32 raspberrypi systemd[1]: satnogs-client.service: Service RestartSec=100ms expired, scheduling restart.
juin 06 20:50:32 raspberrypi systemd[1]: satnogs-client.service: Scheduled restart job, restart counter is at 1365.
juin 06 20:50:32 raspberrypi systemd[1]: Stopped SatNOGS client.
juin 06 20:50:32 raspberrypi systemd[1]: Started SatNOGS client.
juin 06 20:50:34 raspberrypi satnogs-client[5261]: Traceback (most recent call last):
juin 06 20:50:34 raspberrypi satnogs-client[5261]: File â/var/lib/satnogs/bin/satnogs-clientâ, line 5, in
juin 06 20:50:34 raspberrypi satnogs-client[5261]: from satnogsclient import main
juin 06 20:50:34 raspberrypi satnogs-client[5261]: File â/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/init.pyâ, line 21, in
juin 06 20:50:34 raspberrypi satnogs-client[5261]: logging.basicConfig(format=settings.LOG_FORMAT, level=getattr(logging, settings.LOG_LEVEL))
juin 06 20:50:34 raspberrypi satnogs-client[5261]: AttributeError: module âloggingâ has no attribute 'DEBUG â
juin 06 20:50:34 raspberrypi systemd[1]: satnogs-client.service: Main process exited, code=exited, status=1/FAILURE
juin 06 20:50:34 raspberrypi systemd[1]: satnogs-client.service: Failed with result âexit-codeâ.
juin 06 20:50:35 raspberrypi systemd[1]: satnogs-client.service: Service RestartSec=100ms expired, scheduling restart.
juin 06 20:50:35 raspberrypi systemd[1]: satnogs-client.service: Scheduled restart job, restart counter is at 1366.
juin 06 20:50:35 raspberrypi systemd[1]: Stopped SatNOGS client.
juin 06 20:50:35 raspberrypi systemd[1]: Started SatNOGS client.
juin 06 20:50:36 raspberrypi satnogs-client[5264]: Traceback (most recent call last):
juin 06 20:50:36 raspberrypi satnogs-client[5264]: File â/var/lib/satnogs/bin/satnogs-clientâ, line 5, in
juin 06 20:50:36 raspberrypi satnogs-client[5264]: from satnogsclient import main
juin 06 20:50:36 raspberrypi satnogs-client[5264]: File â/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/init.pyâ, line 21, in
juin 06 20:50:36 raspberrypi satnogs-client[5264]: logging.basicConfig(format=settings.LOG_FORMAT, level=getattr(logging, settings.LOG_LEVEL))
juin 06 20:50:36 raspberrypi satnogs-client[5264]: AttributeError: module âloggingâ has no attribute 'DEBUG â
juin 06 20:50:37 raspberrypi systemd[1]: satnogs-client.service: Main process exited, code=exited, status=1/FAILURE
juin 06 20:50:37 raspberrypi systemd[1]: satnogs-client.service: Failed with result âexit-codeâ.
juin 06 20:50:37 raspberrypi systemd[1]: satnogs-client.service: Service RestartSec=100ms expired, scheduling restart.
juin 06 20:50:37 raspberrypi systemd[1]: satnogs-client.service: Scheduled restart job, restart counter is at 1367.
juin 06 20:50:37 raspberrypi systemd[1]: Stopped SatNOGS client.
juin 06 20:50:37 raspberrypi systemd[1]: Started SatNOGS client.
juin 06 20:50:39 raspberrypi satnogs-client[5267]: Traceback (most recent call last):
juin 06 20:50:39 raspberrypi satnogs-client[5267]: File â/var/lib/satnogs/bin/satnogs-clientâ, line 5, in
juin 06 20:50:39 raspberrypi satnogs-client[5267]: from satnogsclient import main
juin 06 20:50:39 raspberrypi satnogs-client[5267]: File â/var/lib/satnogs/lib/python3.7/site-packages/satnogsclient/init.pyâ, line 21, in
juin 06 20:50:39 raspberrypi satnogs-client[5267]: logging.basicConfig(format=settings.LOG_FORMAT, level=getattr(logging, settings.LOG_LEVEL))
juin 06 20:50:39 raspberrypi satnogs-client[5267]: AttributeError: module âloggingâ has no attribute 'DEBUG â
juin 06 20:50:39 raspberrypi systemd[1]: satnogs-client.service: Main process exited, code=exited, status=1/FAILURE
juin 06 20:50:39 raspberrypi systemd[1]: satnogs-client.service: Failed with result âexit-codeâ.
juin 06 20:50:39 raspberrypi systemd[1]: satnogs-client.service: Service RestartSec=100ms expired, scheduling restart.
juin 06 20:50:39 raspberrypi systemd[1]: satnogs-client.service: Scheduled restart job, restart counter is at 1368.
juin 06 20:50:39 raspberrypi systemd[1]: Stopped SatNOGS client.
juin 06 20:50:39 raspberrypi systemd[1]: Started SatNOGS client.
here copy of my console
I changed debug by info I got the next screen
[I changed info to ERROR I got the following screen
juin 06 21:15:15 raspberrypi satnogs-client[7214]: raise BadDsn(âUnsupported scheme %râ % parts.scheme)
juin 06 21:15:15 raspberrypi satnogs-client[7214]: sentry_sdk.utils.BadDsn: Unsupported scheme ââ
juin 06 21:15:15 raspberrypi systemd[1]: satnogs-client.service: Main process exited, code=exited, status=1/FAILURE
juin 06 21:15:15 raspberrypi systemd[1]: satnogs-client.service: Failed with result âexit-codeâ.
juin 06 21:15:15 raspberrypi systemd[1]: satnogs-client.service: Service RestartSec=100ms expired, scheduling restart.
juin 06 21:15:15 raspberrypi systemd[1]: satnogs-client.service: Scheduled restart job, restart counter is at 221.
juin 06 21:15:15 raspberrypi systemd[1]: Stopped SatNOGS client.
juin 06 21:15:15 raspberrypi systemd[1]: Started SatNOGS client.
Isnât the log level supposed to be a number? Like 10
for debug?
I"'ve had problems setting the log level before, the setting is far from intuitive.
I will need more explanation to understand
in the documentation it says
LOG_LEVEL
Définissez le niveau de journalisation du client SatNOGS, les valeurs disponibles : ERROR
, WARNING
, INFO
etDEBUG
I have the following error message
juin 06 22:01:33 raspberrypi satnogs-client[11448]: satnogsclient.scheduler.tasks - ERROR - 401 Client Error: Unauthorized for url: https://network.satnogs.org/api/jobs/?ground_station=2237&lat=45.379&lon=4.823&alt=230.
If I put the address in my web browser I access the page. The problem is with the pi.
How to change the missing authorization?
best regard
thank you for your reply
