Here is my :
versions": {
“satnogs-client”: “1.5.1”,
“satnogs-client-ansible”: “202105301943”,
“satnogs-flowgraphs”: “1.3.1-1”,
“gr-satnogs”: “2.2.1.0-1”,
“gr-soapy”: “2.1.3.1-1”,
“gnuradio”: “3.8.2.0-14satnogs2”,
“satnogs-config”: “0.12”
“state”: {
“is-applied”: true,
“pending-tags”: null
“system”: {
“date”: “2021-08-03T12:25:31.009597+00:00”,
“distribution”: {
“DESCRIPTION”: “Debian GNU/Linux 10 (buster)”,
“RELEASE”: “10”,
“CODENAME”: “buster”,
“ID”: “Debian”
“pending-updates”: true,
“platform”: {
“system”: “Linux”,
“node”: “cceres_team”,
“release”: “4.19.0-17-amd64”,
“version”: “#1 SMP Debian 4.19.194-3 (2021-07-18)”,
“machine”: “x86_64”,
“processor”: “”
“memory”: {
“total”: 16498630656,
“available”: 12748361728,
“percent”: 22.7,
“used”: 3089199104,
“free”: 11634016256,
“active”: 3692126208,
“inactive”: 833572864,
“buffers”: 158924800,
“cached”: 1616490496,
“shared”: 349310976,
“slab”: 205832192
“disk”: {
“total”: 231216836608,
“used”: 24934731776,
“free”: 194465546240,
“percent”: 11.4
“configuration”: {
“gpsd_enabled”: true,
“hamlib_utils_rot_enabled”: true,
“hamlib_utils_rot_opts”: “-m 603 -r /dev/ttyS1 -s 9600 -T localhost -t 4533 -vvvvv”,
“satnogs_antenna”: “RX”,
“satnogs_artifacts_api_token”: “******************************************************”,
“satnogs_gain_mode”: “Settings Field”,
“satnogs_log_level”: “INFO”,
“satnogs_other_settings”: “LNA=12,MIX=8,VGA=11”,
“satnogs_rot_baud”: “9600”,
“satnogs_rot_model”: “ROT_MODEL_NETROTCTL”,
“satnogs_rot_port”: “localhost:4533”,
“satnogs_rx_bandwidth”: “9.0e6”,
“satnogs_rx_samp_rate”: “2.5e6”,
“satnogs_soapy_rx_device”: “driver=airspy”,
“satnogs_station_elev”: “120”,
“satnogs_station_id”: “1062”,
“satnogs_station_lat”: “48.807”,
“satnogs_station_lon”: “2.229”,
“sentry_enabled”: true,
“udp_dump_host”: “localhost”
journalctl -f -u satnogs-client.service: give me currently journal or I need journal since 2021/08/01.
What do you mean by If your system isn’t crashing?
I’m using a lest kernel version…
cheers,
cceres_team.
