How to do some client adjustments
This document is an attempt on describing how to adjust a SatNOGS client properly
Structure:
  • Prerequisites / dependencies
    • Hardware (Pi3, RTL-SDR)
    • Software (satnogs-client, gqrx)
  • SatNOGS station adjustments
    • Setting client to standalone mode
    • Starting RTL-SDR spectrum server (rtl_tcp)
    • Connecting to the spectrum server
    • Adjusting ppm-error
    • Adjusting gain settings
  • Enhancements
    • Hacking the waterfall plot script (deprecated with some next release)
    • running rotator interface and rig interface via network
    • Adjusting gain settings with external LNA
Prerequisites / dependencies:
Starting your journey at https://wiki.satnogs.org/ you will get a quick
overview. Assuming you read all the available ā€œgetting startedā€ pages linked to
under ā€œBuildā€ and ā€œOperateā€ you have already done your first observations and
you already have some waterfalls in the staging environment.
Now you come to a point you want to know, how well your station is performing.
If you did not do this already, this is the perfect time to install gqrx on your
local computer.
gqrx
SatNOGS station adjustments:
To start some kind of ā€œadjustmentā€ and ā€œcalibrationā€, please connect to your
RasPi’s local web interface. By default the URL is something like
ā€œhttp://192.168.0.5:5000ā€.
In the upper right corner there is a big green button where you can set your
ground station in standalone mode.
Network Mode:
Standalone Mode:
Do not forget to set this back to network mode when done with your adjustments!
While your station is in standalone mode, no observations from the SatNOGS
network will be executed!
After setting to standalone, please SSH to your SatNOGS RasPi with your well
known user account.
After successful authorization you will be prompted like this:
Linux satnogs190-dev 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Jan 12 07:34:11 2018 from 192.168.10.35
pd@satnogs190-dev:~ $
Now go ahead and start the ā€œRTL SDR spectrum serverā€:
$ rtl_tcp -a 0.0.0.0
You will get an output like this, if everything is fine:
Found 1 device(s):
  0:  Generic, RTL2832U, SN: 77771111153705700
Using device 0: Generic RTL2832U
[R82XX] PLL not locked!
Tuned to 100000000 Hz.
listening...
Use the device argument 'rtl_tcp=0.0.0.0:1234' in OsmoSDR (gr-osmosdr) source
to receive samples in GRC and control rtl_tcp parameters (frequency, gain, ...).
No further output will be generated until you connect to this server. Hitting
C-c will stop it and the command line appears. You will have to stop this server
if you want to go back to network mode - do not forget about this!
Now go ahead and start gqrx.
You will have to go to the setup menu, either by
clicking on the ā€œhardeā€ symbol, or navigating through the menu item called ā€œFile →
I/O Devicesā€
  • Click on ā€œDeviceā€ and chose ā€œRTL-SDR Spectrum Serverā€
  • Edit ā€œDevice stringā€ to match your RasPi’s IP address, Port defaults to 1234,
    which is the same as the default setting for your server you just started on
    the RasPi
  • Set ā€œInput Rateā€ to something network friendly - we do not need the whole
    spectrum the RTL SDR is able to convert. 1,8 MSPS (1800000) should be OK
    Depending on this setting your network will get very busy. Using wireless LAN
    is not recommended. Every sample has a data size of 16 bits, so the previous
    setting of 1,8MSPS/s results in a network load of 28,8 MBit/s:
    1,8 MSPS * 16 bit/s = 28,8 MBit/s
  • ā€œAudio Output → Deviceā€ and ā€œ-> Sample rateā€ should be set by default,
    values on average soundcards would be something like ā€œDefault, 48 kHzā€
  • Close the dialogue by clicking ā€œOKā€
Your RTL-SDR spectrum server on the RasPi should now show up a connection from
your computer running gqrx.
client accepted!
set gain mode 1
set agc mode 0
set direct sampling 0
Disabled direct sampling mode
set offset tuning 0
set sample rate 960000
ll+, now 1
ll+, now 2
set freq correction 42
set freq 144500000
set gain mode 0
set agc mode 1
set gain 0
set freq 145814000
ll-, now 0
ll+, now 1
ll+, now 2
ll+, now 3
ll+, now 4
ll+, now 5
ll+, now 6
ll+, now 7
ll+, now 8
ll+, now 9
ll+, now 10
ll+, now 11
ll+, now 12
ll+, now 13
The only thing left now is to ā€œStart DSPā€ - from the menu item ā€œFileā€, by
hitting C-d or simply clicking the Play-Button.
Go for a known local HAM radio repeater or a CW beacon transmitter and set your
demodulator accordingly. Narrow Band FM or CW is best to discover ppm error
offset, which is the frequency offset in parts per million (ppm) which is always
there with standard RTL-SDR dongles. It is also highly temperature dependent, so
one might have to re-evaluate this from time to time. Enter the known frequency
of your chosen transmitter (NFM repaeter or CW beacon). I have chosen a very
known CW beacon just some km away from my home: ON4VHF on 144.718000 MHz. Walk
through the tab called ā€œReceiver optionsā€ and change the settings to fit the
beacon: ā€œFilter width Normalā€, ā€œFilter shape Normalā€, ā€œMode CW-Lā€, ā€œAGC
Mediumā€. Set Squelch to something low, so you can hear noise from your
speakers. Maybe you have to Adjust the audio ā€œGainā€ to something like ā€œ0.0
dBā€. You can adjust this to fit your needs to hear noise. With
ppm error, which is default, set to 0.0 ppm, one can just guess where your
receiver is listening. Anyway, just set it to 144.718000 MHz and try to find
your beacon. You can see the result for my RTL SDR dongle down here:
Now got to the tab called ā€œInput controlsā€ and find an input field called
ā€œFreq. correctionā€. By default this should show ā€œ0,0 ppmā€. Set frequency back to
your beacons transmit frequency. After this you have to increase the
Freq. correction value as long until you can hear the beacon. Now zoom into the
panorama by locating your mouse pointer in the range where the frequency values
are printed below the panorama, just above the waterfall. Try to fit the
Freq. correction value as good as possible, that your receivers red indication
line is just in the middle of the transmitters bandwidth.
Now write down the evaluated ppm correction value and exit gqrx as well as the
RTL SDR spectrum server. In the command line now available start satnogs-setup:
$ sudo satnogs-setup
Navigate to ā€œAdvanced → SATNOGS_PPM_ERRORā€ and enter the new value.
Exit the satnogs-setup with ā€œBackā€, then ā€œApply Configurationā€ (this might take
a while) and ā€œBackā€.
You are done with frequency offset correction.
You get a nice tool to do some SDR stuff by the way. Just play around a bit and get familiar with all that stuff. Just keep in mind that, as long as you run the RTL SDR Spectrum server or you have set your client into standalone mode, nothing is done from network.
Enhancements:
Waterfall color improvements:
To get some nicer waterfalls one has to dig into waterfall plotting script. This is a static one and, so far, cannot be configured through satnogs-setup. Anyway: there is no magic behind it and one can understand what the changes are once you have seen them.
Log into the RasPi and start at making a copy of /usr/share/satnogs/scripts/satnogs_waterfall.gp, just in case:
$ cp /usr/share/satnogs/scripts/satnogs_waterfall.gp ~/.
Now you can start editing the script:
$ sudo nano /usr/share/satnogs/scripts/satnogs_waterfall.gp
Search for a line starting with cbtics:
# Spectravue palette and scale
set cbtics (-110, -105, -100, -95, -90, -85, -80, -75, -70, -65, -60, -55, -50, -55, -40)
Comment it out by adding a #, copy, paste and edit that new line that it matches something like this:
#set cbtics (-110, -105, -100, -95, -90, -85, -80, -75, -70, -65, -60, -55, -50, -55, -40)
set cbtics (-90, -85, -80, -75, -70, -65, -60, -55, -50, -55, -45, -40, -35, -40, -25)
Now go ahead and find a line with cbrange:
set ylabel 'Time (seconds)'
set cbrange [-100:-50]
I guess, one already gets the point - change cbrange to match the new cbtics:
#set cbrange [-100:-50]
set cbrange [-85:-35]
Save the file and you are done. Schedule some observations and watch the new colors. Maybe you can just improve it a little more but keep in mind: always keep a bit of the noise floor into the waterfalls, so you can see the whole signals dynamic range. I love it, when there are only a few dots of the noise.
[to be continued…]
P.S.: Comments and discussion welcome!
Hi @DL4PD – this is really awesome! I’ve only just started setting up my own station, and am new both to radio and SDR – so I’m sure I’m going to be referring to this a lot.
It would be excellent if this were available on the wiki so that it’s easy for other folks to find – do you have any objections to having it ported there? I’d be happy to do that work (giving you all the credit, of course :smile:).
The original intention was to write it in the Wiki, but for discussions I thought it would be better to make a new thread. Please feel free to add it in the Wiki.
To find my PPM error I used a NOAA weather radio broadcast station.
There are a lot signals that could be used. There is also a tool to automatically measure the ppm error using GSM cells (they have GPS disciplined oscillators), but CW hast one significant advantage: it is very very narrow band!
If I recall correct, the tool is called ā€˜calibrate’.
Kalibrate. With a K
Tho in my area it had a hard time working.
Initial port made: https://wiki.satnogs.org/Adjusting_the_SatNOGS_Client. Haven’t had a chance to link to it from other pages yet. @DL4PD, thanks again for writing this up! Hope I haven’t butchered it too much – it’s a wiki, so edit to your heart’s content. :smile:
