How to correctly configure Rotator with gpredict or Satnogs using hamlib? MATLAB related
Hi, my name is Julian I am from Colombia, I am a newbie and this is my first post.
I want to capturate Azimuth and Elevation in realtime using Matlab and serial Communication
I had installed Gpredict 2.3.37 on Windows 10
Also Hamlib w32 3.3
And also uploaded “satnogs-rotator-firmware-master” to an arduino UNO from
https://community.libre.space/u/quartapound
I created a Module in gpredict with my location and a generic antenna to communicate with hamlib on localhost and all default options
Then, with the Arduino UNO plugged in, I started hamlib with the following line on CMD:
“C:\Program Files (x86)\hamlib-w32-3.3\bin\rotctld” rotctld -m 204 -r COM10 -s 9600 -T 127.0.0.1 -t 4533 -C timeout=500 -C retry=0 -vvvvvvvv > pause
Everything looks fine untill now but then when I hit “Engage” on gpredict the CMD console shows this ERROR:
read_string(): Timed out 1.49158 seconds after 0 chars
easycomm_transaction read_string failed with status -5
easycomm_rot_get_position got error: -5
No, don’t have any electronics mounted besides the Arduino UNO with no Shield nor any PCB, just a Serial to USB converter used for MATLAB communication
The other day I did the same and it worked, here is a video:
youtu.be/rPlLijxaUcs
Any ideas on why is it not working now?
I also created a Station on SatNOGS network and used “image_2020-03-04-Raspbian-SatNOGS-lite” or “artifacts.zip” on a Raspberry Pi 4 and configured the basic setup, the /dev/ttyACM0, and connected the arduino but I didn’t get any data on the serial port apart from “ID;” or “FA;”
I feel this is a configuration related problem but I’m no expert, I hope you can help me
Thank you for the long reading and any help will be very much appreciated.
Hi Julian welcome to the community. It’s an interesting and frustrating hobby. I too have been trying to build an antenna rotator as you can see from my blog (http://www.cyclebikeapp.com/satnogs)
I have seen your ERROR before. Rotctld must get a position reply from the easycomm Arduino code or it disconnects. Usually this comes from a position encoder on the rotator, but you say you don’t have any hardware connected. For debugging, I have just used a command to send a reply when easycomm receives a position command. Something like Serial.print(“AZ123 EL45”); Notice the space between 3 and E.
(I believe you have been using the code on gitlab here (https://gitlab.com/Quartapound/satnogs-rotator-firmware), not the link you posted.)
Tom
Hi Tom, thank you for replying
Yes, that is the code I am using, sorry about the posting, I am learning how to do it just now
I will try this and let you know how it goes.
Thanks.
