I managed to get the latest version of the SatNOGS rotator controller firmware to talk to the PC directly by modifying the easycomm.h file.
I disabled the RS485 protocol and replaced it with Serial commands (replace every rs485 with the word Serial and make sure you call serial.begin in setup)… it was pretty easy to do once I figured out. started working right away… you should be able to easily switch between the two by just replacing the easycomm.h file and recompiling/reuploading.
here’s my easycomm file. I’m running it on an Arduno Uno R3. communicates with Gpredict on Windows10 perfectly (connected directly to PC via usb)
* @file easycomm.h
* It is a driver for easycomm 3 protocol as referred, in Hamlib.
* Licensed under the GPLv3
#ifndef LIBRARIES_EASYCOMM_H_
#define LIBRARIES_EASYCOMM_H_
#include <Arduino.h>
#include <WString.h>
#include <avr/wdt.h>
//#include "rs485.h"
#include "rotator_pins.h"
#include "globals.h"
#define RS485_TX_TIME 9 ///< Delay "t"ms to write in serial for RS485 implementation
#define BUFFER_SIZE 256 ///< Set the size of serial buffer
#define BAUDRATE 19200 ///< Set the Baudrate of easycomm 3 protocol
//rs485 rs485(RS485_DIR, RS485_TX_TIME);
@brief Class that functions for easycomm 3 implementation
class easycomm {
public:
@brief Initialize the RS485 bus
void easycomm_init() {
// rs485.begin(BAUDRATE);
Serial.begin(9600);
@brief Get the commands from RS485 and response to the client
void easycomm_proc() {
char buffer[BUFFER_SIZE];
char incomingByte;
char *Data = buffer;
char *rawData;
static uint16_t BufferCnt = 0;
char data[100];
String str1, str2, str3, str4, str5, str6;
// Read from serial
while (Serial.available() > 0) {
incomingByte = Serial.read();
// Read new data, '\n' means new pacakage
if (incomingByte == '\n' || incomingByte == '\r') {
buffer[BufferCnt] = 0;
if (buffer[0] == 'A' && buffer[1] == 'Z') {
if (buffer[2] == ' ' && buffer[3] == 'E' &&
buffer[4] == 'L') {
// Send current absolute position in deg
str1 = String("AZ");
str2 = String(control_az.input, 1);
str3 = String(" EL");
str4 = String(control_el.input, 1);
str5 = String("\n");
Serial.print(str1 + str2 + str3 + str4 + str5);
} else {
// Get the absolute position in deg for azimuth
rotator.control_mode = position;
rawData = strtok_r(Data, " ", &Data);
strncpy(data, rawData + 2, 10);
if (isNumber(data)) {
control_az.setpoint = atof(data);
// Get the absolute position in deg for elevation
if (rawData[0] == 'E' && rawData[1] == 'L') {
control_el.setpoint = atof(data);
} else if (buffer[0] == 'E' && buffer[1] == 'L') {
} else if (buffer[0] == 'V' && buffer[1] == 'U') {
// Elevation increase speed in mdeg/s
rotator.control_mode = speed;
strncpy(data, Data + 2, 10);
// Convert to deg/s
control_el.setpoint_speed = atof(data) / 1000;
} else if (buffer[0] == 'V' && buffer[1] == 'D') {
// Elevation decrease speed in mdeg/s
// Convert to deg/s
control_el.setpoint_speed = - atof(data) / 1000;
} else if (buffer[0] == 'V' && buffer[1] == 'L') {
// Azimuth increase speed in mdeg/s
// Convert to deg/s
control_az.setpoint_speed = atof(data) / 1000;
} else if (buffer[0] == 'V' && buffer[1] == 'R') {
// Azimuth decrease speed in mdeg/s
// Convert to deg/s
control_az.setpoint_speed = - atof(data) / 1000;
} else if (buffer[0] == 'S' && buffer[1] == 'A' &&
buffer[2] == ' ' && buffer[3] == 'S' &&
buffer[4] == 'E') {
// Stop Moving
control_az.setpoint = control_az.input;
control_el.setpoint = control_el.input;
} else if (buffer[0] == 'R' && buffer[1] == 'E' &&
buffer[2] == 'S' && buffer[3] == 'E' &&
buffer[4] == 'T') {
// Reset the rotator, go to home position
rotator.homing_flag = false;
} else if (buffer[0] == 'P' && buffer[1] == 'A' &&
buffer[2] == 'R' && buffer[3] == 'K' ) {
// Park the rotator
control_az.setpoint = rotator.park_az;
control_el.setpoint = rotator.park_el;
} else if (buffer[0] == 'V' && buffer[1] == 'E') {
// Get the version if rotator controller
str1 = String("VE");
str2 = String("SatNOGS-v2.2");
str3 = String("\n");
Serial.print(str1 + str2 + str3);
} else if (buffer[0] == 'I' && buffer[1] == 'P' &&
buffer[2] == '0') {
// Get the inside temperature
str1 = String("IP0,");
str2 = String(rotator.inside_temperature, DEC);
buffer[2] == '1') {
// Get the status of end-stop, azimuth
str1 = String("IP1,");
str2 = String(rotator.switch_az, DEC);
buffer[2] == '2') {
// Get the status of end-stop, elevation
str1 = String("IP2,");
str2 = String(rotator.switch_el, DEC);
buffer[2] == '3') {
// Get the current position of azimuth in deg
str1 = String("IP3,");
str2 = String(control_az.input, 2);
buffer[2] == '4') {
// Get the current position of elevation in deg
str1 = String("IP4,");
str2 = String(control_el.input, 2);
buffer[2] == '5') {
// Get the load of azimuth, in range of 0-1023
str1 = String("IP5,");
str2 = String(control_az.load, DEC);
buffer[2] == '6') {
// Get the load of elevation, in range of 0-1023
str1 = String("IP6,");
str2 = String(control_el.load, DEC);
buffer[2] == '7') {
// Get the speed of azimuth in deg/s
str1 = String("IP7,");
str2 = String(control_az.speed, 2);
buffer[2] == '8') {
// Get the speed of elevation in deg/s
str1 = String("IP8,");
str2 = String(control_el.speed, 2);
} else if (buffer[0] == 'G' && buffer[1] == 'S') {
// Get the status of rotator
str1 = String("GS");
str2 = String(rotator.rotator_status, DEC);
} else if (buffer[0] == 'G' && buffer[1] == 'E') {
// Get the error of rotator
str1 = String("GE");
str2 = String(rotator.rotator_error, DEC);
} else if(buffer[0] == 'C' && buffer[1] == 'R') {
// Get Configuration of rotator
if (buffer[3] == '1') {
// Get Kp Azimuth gain
str1 = String("1,");
str2 = String(control_az.p, 2);
} else if (buffer[3] == '2') {
// Get Ki Azimuth gain
str1 = String("2,");
str2 = String(control_az.i, 2);
} else if (buffer[3] == '3') {
// Get Kd Azimuth gain
str1 = String("3,");
str2 = String(control_az.d, 2);
} else if (buffer[3] == '4') {
// Get Kp Elevation gain
str1 = String("4,");
str2 = String(control_el.p, 2);
} else if (buffer[3] == '5') {
// Get Ki Elevation gain
str1 = String("5,");
str2 = String(control_el.i, 2);
} else if (buffer[3] == '6') {
// Get Kd Elevation gain
str1 = String("6,");
str2 = String(control_el.d, 2);
} else if (buffer[3] == '7') {
// Get Azimuth park position
str1 = String("7,");
str2 = String(rotator.park_az, 2);
} else if (buffer[3] == '8') {
// Get Elevation park position
str1 = String("8,");
str2 = String(rotator.park_el, 2);
} else if (buffer[3] == '9') {
// Get control mode
str1 = String("9,");
str2 = String(rotator.control_mode);
} else if (buffer[0] == 'C' && buffer[1] == 'W') {
// Set Config
if (buffer[2] == '1') {
// Set Kp Azimuth gain
rawData = strtok_r(Data, ",", &Data);
strncpy(data, rawData + 4, 10);
control_az.p = atof(data);
} else if (buffer[2] == '2') {
// Set Ki Azimuth gain
control_az.i = atof(data);
} else if (buffer[2] == '3') {
// Set Kd Azimuth gain
control_az.d = atof(data);
} else if (buffer[2] == '4') {
// Set Kp Elevation gain
control_el.p = atof(data);
} else if (buffer[2] == '5') {
// Set Ki Elevation gain
control_el.i = atof(data);
} else if (buffer[2] == '6') {
// Set Kd Elevation gain
control_el.d = atof(data);
} else if (buffer[2] == '7') {
// Set the Azimuth park position
rotator.park_az = atof(data);
} else if (buffer[2] == '8') {
// Set the Elevation park position
rotator.park_el = atof(data);
} else if (buffer[0] == 'R' && buffer[1] == 'S'
&& buffer[2] == 'T') {
// Custom command to test the watchdog timer routine
while(1)
} else if (buffer[0] == 'R' && buffer[1] == 'B') {
// Custom command to reboot the uC
wdt_enable(WDTO_2S);
while(1);
// Reset the buffer an clean the serial buffer
BufferCnt = 0;
Serial.flush();
} else {
// Fill the buffer with incoming data
buffer[BufferCnt] = incomingByte;
BufferCnt++;
private:
bool isNumber(char *input) {
for (uint16_t i = 0; input[i] != '\0'; i++) {
if (isalpha(input[i]))
return false;
return true;
#endif /* LIBRARIES_EASYCOMM_H_ */
