I have got satnogsclient up and running on my RPi. It is recognized by the software on network-dev.
My radio is an Icom 821H and I know the arguments to use in an invocation of rigctld:
rigctld -m334 -r /dev/ttyUSB0 -s 19200 -c 0x60
My question is simply this: Where do I put these arguments so that satnogsclient will use them when it starts rigctld. (rigctld is started but only with the (default) argument -t 4532).
However, if I’m understanding things right, these settings don’t work the same as the other
settings – that is, they’re not settable in the same way other settings are (tech detail: they’re not taken from environment variables the way, say, RIG_IP is). And of course, there isn’t support for the “-c” argument.
It would be good to get someone from the SatNOGS team to confirm all that. Assuming I’ve understood it all correctly, this should be a simple bug to fix: add support for setting the variables, add in the “-c” argument, and allow them all to be set by the satnogs-client-ansible script (which, if you’re using the [Raspbian image (https://wiki.satnogs.org/Raspberry_Pi_3#Raspbian), is how they’ll get set on your Raspberry Pi). I’ll file a bug and see if I can get a PR in to fix this.
Hi @saintaardvark. I tried to insert one of the arguments (the RIG_MODEL) directly into settings.py, but all I got out of it was this very informative message:
rig_open: error = IO error
(irony may occur) and rigctld was not started.
I subsequently tried to insert some log messages into tasks.py to see what arguments were actually used in the rigctld call, but they appear to have vanished into thin air. The same happened when I brutally changed the logger call to a print statement.
I have tried to understand the way satnogsclient uses the logging module but so far with meager results. Hopefully somebody (you?) could give me some pointers to better understanding.
@m6lzt – thanks, I hadn’t noticed that! I was looking through the satnogs-client code to see how it built up the arguments for rigctl – not rigctld. HAMLIB_UTILS_RIG_OPTS is used to build the file /etc/default/hamlib-utils, which in turn is used as settings for rigctld…so I got that wrong (doh). @oz6bl, apologies for the mixup!
