How to add a 2nd antenna to my system and listen on UHF?
I should like to add a 2nd antenna to my SatNogs system. Now I only have a VHF turnstile but want to listen on UHF and VHF …
Can somebody explain me how this can be done? Can I reconfigure the Client ?
ON4API
If using a single SDR, first you must add the antenna with a “duplexer” (actually a diplexer) like the MFJ-916 (or similar).
Then, you simply go into your station setup and click edit, and add the new antenna that covers the UHF range you want:
https://network.satnogs.org/stations/272/
(change the station number to the appropriate one, of course).
Hello Roy,
Thanks for your response. I did not know it was that simple.
I looked into my RasberryPi client but found it in my Dashboard.
Thanks very much for your tip.
Krist ON4API
