Having empty waterfall issues with another station today. #908 which I put in testing mode as soon as I got the email letting me know that it was returning abnormal results.
Looked at my own notes from the wiki and can see that I have enough hard drive.
I don’t have any rouge satnog clients running.
Looking the log file, I see this in a pattern;
Aug 15 19:58:46 raspberrypi satnogs-client[18169]: 2019-08-15 19:58:46,830 - apscheduler.executors.default - INFO - Job "get_jobs (trigger: interval[0:01:00], next run at: 2019-08-15 19:59:45 UTC)" executed successfully
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: 2019-08-15 19:59:26,018 - apscheduler.executors.default - INFO - Running job "spawn_observer (trigger: date[2019-08-15 19:59:26 UTC], next run at: 2019-08-15 19:59:26 UTC)" (scheduled at
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: 2019-08-15 19:59:26,108 - satnogsclient - ERROR - Cannot connect to socket 127.0.0.1:4533
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: Exception in thread Thread-384:
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: Traceback (most recent call last):
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: self.run()
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: File "/usr/lib/python2.7/threading.py", line 754, in run
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: self.__target(*self.__args, **self.__kwargs)
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py", line 142, in _status_interface
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: sock.bind()
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/commsocket.py", line 104, in bind
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: self.s.bind((self._TCP_IP, self._TCP_PORT))
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: File "/usr/lib/python2.7/socket.py", line 228, in meth
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: return getattr(self._sock,name)(*args)
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: error: [Errno 98] Address already in use
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: 2019-08-15 19:59:26,149 - satnogsclient - ERROR - Cannot connect to socket 127.0.0.1:4533
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: Exception in thread Thread-383:
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py", line 134, in _communicate_tracking_info
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: self.send_to_socket(p, sock)
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py", line 180, in send_to_socket
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: position = sock.send("p\n").split('\n')
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/commsocket.py", line 76, in send
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: self.s.send(message)
Aug 15 19:59:26 raspberrypi satnogs-client[18169]: error: [Errno 32] Broken pipe
Aug 15 19:59:27 raspberrypi satnogs-client[18169]: 2019-08-15 19:59:27,064 - apscheduler.executors.default - INFO - Job "spawn_observer (trigger: date[2019-08-15 19:59:26 UTC], next run at: 2019-08-15 19:59:26 UTC)" executed successfully
Aug 15 19:59:45 raspberrypi satnogs-client[18169]: 2019-08-15 19:59:45,909 - apscheduler.executors.default - INFO - Running job "get_jobs (trigger: interval[0:01:00], next run at: 2019-08-15 20:00:45 UTC)" (scheduled at 2019-08-15 19:59:
A
And I see this as well;
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: Exception in thread Thread-385:
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: Traceback (most recent call last):
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: self.run()
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: File "/usr/lib/python2.7/threading.py", line 754, in run
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: self.__target(*self.__args, **self.__kwargs)
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py", line 123, in _communicate_tracking_info
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: self.check_observation_end_reached()
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py", line 168, in check_observation_end_reached
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: self.trackstop()
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: File "/var/lib/satnogs/local/lib/python2.7/site-packages/satnogsclient/observer/worker.py", line 164, in trackstop
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: os.killpg(os.getpgid(self._gnu_proc.pid), signal.SIGINT)
Aug 15 20:09:42 raspberrypi satnogs-client[18169]: OSError: [Errno 3] No such process
I have not rebooted as I don’t want to lose the passes that I have if I can.
Thanks for your help once again.
