I moved from a Raspberry Pi to a 686 desktop PC to use the 6meg sample rate of my airSpyMini.
How do I check or set that sample rate?
I see the hardware settings here;
But they look to be in hex?
What hex number should I put in there to ensure I am using my AirSpyMini to its full capacity?
cgbsat
2
No, they are in scientific notation: 3e6 is 3x10^6 = 3000000 = 3Msps.
Oh… Heh, yeah, that makes sense… I was making it harder than it needed to be…
6e6 it is then.
Thanks.
I have edited the file and ‘applied’ the configuration though restarting ‘satnogs-setup’.
Is there a command or way to check the sample rate?
cgbsat
5
Not really, though you will see a high CPU load when the SatNOGS demodulators will run with 6Msps. Why are you running it that high?
There was a hint in this community that higher was better for decoding.
Did I misunderstand it?
cgbsat
7
You may be right. I think the airspy’s have a somewhat nicer/flatter bandpass at higher sample rates.
