I would like Inmarsat 4-F3 33278 to be added.
It was being used by Outernet 2.0, but still carries some interesting data.
Why: The Inmarsat satellites are geosynchronous and have a very strong signal that can be received with fixed a 3 element patch antenna, an RTL-SDR with an LNA. These are useful in proving that a setup is working and adds L-Band to the mix of satellite possibilities.
good point… I just tested Inmarsat 4-F1 in dev and its not showing up in pass predictions nor can you manually schedule it. This is likely in the way we use pyephem’s next_pass() call which is going to try to calculate the next rise time - which in this case never happens… I went ahead and filed an issue for this but its not going to be an easy fix: https://gitlab.com/librespacefoundation/satnogs/satnogs-network/issues/471
@WA4OSH thanks for bringing this up, previously nobody has asked about or tried one of the GEO birds… I can add F3 to the db, but its unlikely to be supported by satnogs-network anytime soon.
Alphasat and Inmarsat-4 satellites are Geostat on L-band.
I-4 F1 Asia-Pacific, at 143.5 degrees East.
I-4 F2 EMEA (Europe, Middle East and Africa), at 63.9 degrees East.
I-4 F3 Americas, at 98.4 degrees West.
So, of course, they are always visible.
Their tracks 4-F14-F24-F3 may look “broken”, but remember, they are Geostat and not Geosync. It’s a weird analemma for people that have been looking at LEO’s. They will appear to go up and down around a fixed spot over a day.
This may cause problems for the ephemera? programs, but really should not present a problem for a ground station to track and receive one.
All it takes to receive these birds is an RTL-SDR, a two or three element 4 inch-square patch antenna and an LNA. (or an active patch antenna).
There should not be any reason why satellites with “weird” orbits, or up to L-Band can’t work with the standard SatNOGS setup. The Highly Elliptical Orbit (HEO) or Tundra satellites E.g. SiriusXM, Molniya present a similar problem.
Why should SatNOGS be limited to LEO’s? Why should SatNOGS be limited to VHF and UHF, when the hardware is good up to SHF/L-Band?
You might want to limit the length of an observation of birds that perpetually appear up in the sky.
