I’m using raspberry pi 3 in satellite tracking project and i need to set ground station using GPS but i don’t now how to use gpsd to get gps data to gpredict
Hello @beshoy46,
I’ve just joined the forum and noticed your OP. Which GPS dongle are you using (or plan to use)? There are several flavors of dongles to choose from depending on your requirements. Of course, there are environmental factors to consider for the antenna. Most of the lower cost cost ones cannot withstand the outdoor conditions without proper enclosures but then for your first project you probably do not need the Cadillac/Rolls Royce versions of these.
Kind regards.
